pump gas on 21 cc domes?
  • 4 weeks later...
I have one of your heads on a passion built 4 mill bike would I feel any difference with race fuel??
It depends on your compression. Did Jim recommend pump gas?
just got shee, when talking about race gas, what octane are we talking about.
Usually 101 to 116
I'm at sea level. I would like to know the same thing about 21cc domes. Is it ok to run 93 octane?
With the mods listed in your sig you should be fine
Might as well, im runnin 20cc no advance timing at 1400 feet is 93/94 ok??
You should be fine anywhere above 800'-1000'
Ok, so I guess I'll jump in here too. I normally ride at 8500' in the mountains of Colorado. I have 17cc domes and +4 deg. Sometimes run 93 oct. pump and sometimes 111 oct. race gas. Am I ok?
I would think 93 would be good at 8500'. Have you ever checked your compression at that elevation?
357204[/snapback]
I haven't checked it at that elevation, I live in Denver and have checked it here (5280 ft) it's at 135psi.
You are fine then.
357514[/snapback]
Make me wonder if you are at 135 at 5280 what you'll be at 8250 :)
I run about 170 at 5000 feet and runs great with 103 I never tried striaght 91.
am running 4.5 degrees adv timing also.
