BigRed350x Posted March 22, 2005 Report Posted March 22, 2005 I got some Namura pistons for her. Wondering if anyone has had experience with these? Only $49 ea for the whole kit. Not bad I think. Quote
RNBRAD Posted March 22, 2005 Report Posted March 22, 2005 I got some Namura pistons for her. Wondering if anyone has had experience with these? Only $49 ea for the whole kit. Not bad I think. 342966[/snapback] Try a search, there is a lot of info on those. Quote
richybanshee Posted March 22, 2005 Report Posted March 22, 2005 (edited) Since you got them ... sell them or just put them on. In my Opinion I would put Wiseco's because thay are proven to be strong and reliable. Maybe you did not spend too much $$$$ now but if shee explodes like a grenade ... at first you will be like this then Why the #$%$# did not I buy does Wiseco's? and finallyy : I need some $$$$ to fix my shee. Edited March 22, 2005 by richybanshee Quote
DIRTBIKEZ Posted March 23, 2005 Report Posted March 23, 2005 Only $49 ea for the whole kit. Not bad I think. They were cheap for a reason man. Quote
Nightrider Posted March 27, 2005 Report Posted March 27, 2005 We'll see,just installed a set in my 01'.Stock bores were perfect,no taper,no out of round and .0028 piston clearance after honing.Comp is 125psi On stock ports and compression,they should be fine,or at least I hope they will be. The Namuras, like the Vitos PP have shorter skirts,excessive piston clearance will rattle them to destruction in no time. Quote
