Drag Banshee
superbanshee03
Hey guys, I have a 03 banshee I want to setup for drag mods in signiture. I have t6's and was wondering what pipe to go to. I thought about cpi or rocket's, been trying to sell t6's so if anyone is interested pm me an offer, What other mods do you think would help me out, I have 33pwk's that I am in the process of installing so carbs are out of the way. Could you think of anything else I could do to help me. Thanks
  • Replies 32
  • Created
  • Last Reply
Top Posters In This Topic
Also, can you get your cylinders reported after they have been setup for a certain style of porting? Will a stroker help me that much, you do mean a stroker with stock length rods or do you mean a longer rod like +4 or something? Will I have to have my porting changed with just a stroker or what I have no idea.
342647[/snapback]
It depends on what type of port you have now,yes a stroker will help you out way more,longrod 4mm,i know lots of people that run that combo with a full drag port and those fuckers haul ass,maybe you will have to change your porting for the stroker but not sure on that. :cheers:
im not too firmiliar with dirt drags but here goes:
for tires a lot of guys use Pro wedge 2's for groomed tracks. they hook up well, and so do some others that currently slip my mind.
by chassis i mean your suspension. asphalt draggers tend to use a rigid frame setup. either through the use of struts in place of shocks, or aftermarket frames with no suspension even in the design. sand on the other hand needs a little shock adsorbtion, so most dudes use a Marvin shaw drag type air shock.
and typically yes, your jugs can be ported a lil more to go to a full drag port. also your ported jugs will be useless if you move onto a stroker motor. the extra stroke throws all of the port timings out of whack.
later bro, and good lulck to ya. :cheers:
i would go with a 4mm stroker and ROCKETS!! my 4mm stroker made 3 more hp with the rockets than with cpis. contact dlnoss for a really good head and then also figure out what kind of porting you want. if you are going strictly drag id talk to Ohton racing, a & s, k & t or southern style racing.
check this site for dyno sheets and pictures of rockets..
ROCKET PIPES
if ur full out drag u want out of frame drag pipes. but if it's something uride often all over they would be stickin out kinda far. check into shearer or rocket or maybe even t5's . all great exhaust with a good port. anyone mention passion racing for a port? heard good things bout them in the past. good luck with the build. keep us posted
Will I still be able to ride normal riding with this?
343355[/snapback]
I wouldnt recommend it for just casual trail riding, only drag racing. But if u get a +10 swingarm and out of frame drag pipes u probably wont be riding trails anyway. Just something to think about if you are serious about whippin some ass.
I dont trail ride but do a lot of riding in fields and around woods so I dont want out of frames, I have a KFX 700 for that.
Does anyone have or know where I can get some rockets or cpi's cheap or used I have posted in the swap and trade and for sell forum. I have some t6's and some G3 power curve reeds that I might swap for some good pipes. Since everybody says the t6's arent good for porting even though they speed me up about 5 lengths, I want to see what a set of so called good pipes will do. I will be the guinnei pig on this and report my findings. Do you guys think there will be a big difference. sorry so long.
