dome compression
hi i just bought a cool head,and the dome size is erase so befor puting thats thing on i want to determine dome size ,my way for checking thats is put a plug in the spark ^plug hole and fill with water with a seringe ,but the probleme is thats i dont know if i only fill the cup or if i fill till it come equale of the squish band(lips)please help me thanks by the way sorry for my english i am french i read better than i write :bolt::confused:
Fill it all the way with the spark plug installed. I use rubbing alcohol because of the lower surface tension and a plexiglass plate clamped to the base.
341533[/snapback]
thanks a lots,if i hav don it correctly i have 20 cc is it ok to run 20cc with pump gaz and +4 timing :cheers:
