Routing Fuel Lines
i have 30mm d slides and i routed my fuel lines just like my stock setup ,a long 11' line connected to a split in which 2 lines of equal length 3' branch off  to the left and right :confused:
337214[/snapback]
I know how I'm going to do that. But I am talking about the vent hoses. Like what hose goes on what end and threw what hole.
:D well you called it a fuel line ,what was i suppose to think? :confused:
under each backside a hook is atached to the bowl closest to you and farthest back i belive its on left and right carbs
attach the hose through this loop and connect to the vent outlet on side of each carb
:cheers: oh the nthers the 2 drain lines that run back under your swingarm
