Alky?
cjm02ram
I ran a 350 last year on alky... I ran Mikuni 36mm carb's.... I could have run 34's.... So your carb's should be fine... Just have them converted by someone who knows what they are doing... I didn't run a fuel pump on the 350, but I will be running one on my new motor this year....You will need to install a pingel fuel petcock on your tank, if you already haven't done so.... Hopefully I will have my Banshee all together in a few weeks and I will be going down to St. Joe state park..... Do you ever ride down there????
Like enforcer said, get somebody that knows what they are doing to convert your carbs. Also, I would highly recomend an EGT, this will help alot in getting it dialed in and keeping it from runnig to lean. Im not sure on the fuel pump thing, I would ask my builder or whoever converts my carbs.
i hear its a good idea to factor in a new topend when dialing in a new alcohol setup.
333206[/snapback]
what cole says is true,if your not stricktly draggin i wouldn t bother. i don`t know about a fuel pump with 35mm pwk`s. i run 38mm tmx`s, no fuel pump.
