I'm thinking about putting some intakes on my banshee, what ones are the best?
332504[/snapback]
I think they are all pretty good. Yet to hear of one that was just crap. I use the pro-design unit, a little pricey but well made.
boss racing
got if from passionre nice piece, allows bigger carb to not hit the clutch arm also
I have the prodesign as well, its a nice piece, but I think the BOSS may be better price vs quality. Trinity makes some nice and simple intakes for duel carbs you can find on e-bay for cheap. Vitos makes some and there are many other bilit manifolds out there. If you want to run v-force reeds then there are also many manifolds that are specifically made for v-force, they have 4 short individual runners which look like cross hairs from the front view.
Almost forgot, there are some rubber manifolds that look like stock but fit bigger carbs for a lot less $ than the bilit manifolds. I think Magic Racing sells them.
made my own out of a soild piece of T-6 aluiminum
337330[/snapback]
T-6 is a treatment level not the actual type of aluminum. 4043, 6061, 6063, 7075 are types of aluminum.
I have a set of BOSS that I got from Passion. I also have some of the individual cast intakes from FTZ. I run a bottle on one set of the FTZ's and the other set hasn't been drilled out.
The boss intake has a crossover tube which surves basically the same purpose as the boost mottle. Boost bottle is more about throttle response, not HP output. Most say boost bottle making a difference in performance is a myth anyway.
