Stroker81 Posted February 22, 2005 Report Share Posted February 22, 2005 Does anyone know where i can get my rm250 bigbored? Or know where i can get it sleeved back to stock? Whatever would be cheapest. If you could give me some names of companys that work on bikes. Thanks Quote Link to comment Share on other sites More sharing options...
FoxBansheeRacing Posted February 22, 2005 Report Share Posted February 22, 2005 (edited) Are you sure it has been or needs to be bored? The cylinder wall is made out of a very hard metal similiar to chrome. Mine blew up and the entire intake side piston skirt broke off inside the motor, and the cylinder didnt need to be bored. This was my fathers bike so I'm not 100% sure, but I believe the machine shop said if the cylinder wall was trashed you would have to get a new cylinder because they cant bore the metal. Edited February 22, 2005 by FoxBansheeRacing Quote Link to comment Share on other sites More sharing options...
CombatTalon2 Posted February 22, 2005 Report Share Posted February 22, 2005 you are right, you can not bore the cylinders on later rm250s, they have a nikasil coating. basically you have 2 options. new cylinder, or new sleeve. the sleeve cost about 115.00 from the stealership, and then you have to find a shop to actually put it in your cylinder! Quote Link to comment Share on other sites More sharing options...
zilladude Posted February 22, 2005 Report Share Posted February 22, 2005 Try here- http://www.mt-llc.com/ Quote Link to comment Share on other sites More sharing options...
Stroker81 Posted February 22, 2005 Author Report Share Posted February 22, 2005 I should of said resleeved instead of bored. It has been sleeved bigger than stock beause stock piston is 64.5mm and the piston that is in it now is a 69mm. I just want it so i can ride it. Can they a stock sleeve back in? Could they just put a new 265 sleeve in? I am not very good at this shit sorry if i sound dum. thanks Quote Link to comment Share on other sites More sharing options...
