At idle it dies
islandsurfer
Alright... i bought it used and from What I see so far not for sure: It has SST and PCii exhaust a Cool head I don't know what size dome, Keihlin Carbs ( I don't know what size), Boost bottle, K and N pods with covers, and I played with idle screw (If i mess with one I have to do the same with other?? Thanks
326583[/snapback]
need to know what carbs these are and what jetting is in them right now. on the side of the carb it should say something like, 33pwk, 34pj, 35pwk or somethinkg along those lines. find out which carbs they are. also pull off the carbs and see what main and pilot is in there. sounds like its kinda rich on the pilot from what you are saying but itd be best to know for sure what jets are there..find out and let us know.
326657[/snapback]
Alright will pull them today and find out... Thanks
Tha carb doesn't say the size but here is what I got: 70PA3 below the PWK, the top opeing is 1.5 inches the part that attaches to the intake is 1.5 inches and the part that attaches to the air filter is 2 inches... I also noticed a stage ebgraved on the intakes... The jet size I will get later.. Thanks
here are the numbers... 78    pilot:65    main:165
330128[/snapback]
65 is rich as hell for the pilot.
I run a 404 big bore 19cc coolhead(which doesn't affect jetting), rockets, vforce delta 2's, mild port, the trinity single carb setup with a 35mm pwk and my pilots a 52 starts first kick with the choke and idles almost immediatly with the choke off. You should be down around a 45.
I bought it used... i figured it was high, when I saw the number.... I don't know to much about the Shee.... All I know is what I see... I was told there was engine work, but don't know what kind... So if I goto a 45 for the main it won't run so rich and will idle?? It spit globs of oil out the back and the plug was wet and black... Thanks, also where can I get a pilot jet?? does come in sets or can i get it seperate??
take the pilot out than try the local yamaha dealer you can get them for around $3. they can also be bought in sets. A wet plug is an indicator of a rich condition or a fouled plug, one, the other or both. Pop in the new pilot and some new plugs then let us know where you are at.
islandsurfer what's the mesurement on the id of the intake side ? that will tell us what size carb's you have bro. If the inside is 1.5" then you have 38mm carb's.
