Badshee22 Posted February 16, 2005 Report Share Posted February 16, 2005 I have an 01 Banshee, its bored over one size up from stock, has a cool head, port and pollish, reeds, boost bottle etc. before i did the engine work I changed the stock gearing and went down one tooth on the front sprocket and up one on the rear(Use to a 250R). I run both 10 paddle haulers and sand stars depending on conditions. My bike runs perfect with the exception of its too low geared now and I am having trouble keeping the wheels on the ground. I like to drag race, but I also like to jump and trail ride (on the dunes only) my swing arm is stock, I need some advice on gearing, tires and swing arm length. I also need some clarification on what exactly a -2 swing arm is? Does that mean 2 in shorter or longer? Quote Link to comment Share on other sites More sharing options...
kw04 Posted February 16, 2005 Report Share Posted February 16, 2005 -2 2 inches shorter +2 2 inches longer and so on Quote Link to comment Share on other sites More sharing options...
stclark816 Posted February 16, 2005 Report Share Posted February 16, 2005 I like 16tooths on mine. If ur bike can pull it, why not gear it a little higher? Quote Link to comment Share on other sites More sharing options...
. Posted February 16, 2005 Report Share Posted February 16, 2005 If you're running sand, you want to go longer, if running dirt you want to go shorter. Sand grabs a heck of a lot harder than dirt. Quote Link to comment Share on other sites More sharing options...
ledofthezep Posted February 16, 2005 Report Share Posted February 16, 2005 If you're running sand, you want to go longer, if running dirt you want to go shorter. Sand grabs a heck of a lot harder than dirt. 324683[/snapback] Jiberish! hehe...that tends to be the trendy thing to do. I ride mostly sand & run a -2 swingarm, also +2+1 a-arms & love it. No complaints and/or regrets. Unless I go drag, I'll never go over stock. Now I run 8paddles vs. 9paddles with my stock arm. I've never tried anything other than a +2 arm, and it wasn't on my quad so I can't talk negative about that at all & won't. It was a nice ride, but not what I was looking for. Just MHO...suits my style of riding. Quote Link to comment Share on other sites More sharing options...
Badshee22 Posted February 17, 2005 Author Report Share Posted February 17, 2005 Jiberish! hehe...that tends to be the trendy thing to do. I ride mostly sand & run a -2 swingarm, also +2+1 a-arms & love it. No complaints and/or regrets. Unless I go drag, I'll never go over stock. Now I run 8paddles vs. 9paddles with my stock arm. I've never tried anything other than a +2 arm, and it wasn't on my quad so I can't talk negative about that at all & won't. It was a nice ride, but not what I was looking for. Just MHO...suits my style of riding. 324718[/snapback] what is the advantage of running a -2 swing arm in the sand; what kind of gearing do you run. thanks for the reply. Quote Link to comment Share on other sites More sharing options...
OR_Banshee Posted February 17, 2005 Report Share Posted February 17, 2005 I have an 01 Banshee, its bored over one size up from stock, has a cool head, port and pollish, reeds, boost bottle etc. before i did the engine work I changed the stock gearing and went down one tooth on the front sprocket and up one on the rear(Use to a 250R). I run both 10 paddle haulers and sand stars depending on conditions. My bike runs perfect with the exception of its too low geared now and I am having trouble keeping the wheels on the ground. I like to drag race, but I also like to jump and trail ride (on the dunes only) my swing arm is stock, I need some advice on gearing, tires and swing arm length. I also need some clarification on what exactly a -2 swing arm is? Does that mean 2 in shorter or longer? 324626[/snapback] I run a 13/41 in the dunes and with my mods it's decent gearing. I've also got a +4 swinger and for my style of riding it's perfect. It can be a bitch at times in tight trails but other than that its a good all around set up. Just my .02 but 10 paddle Haulers may be a bit much for your mods, unless they aren't the Extremes. If they are regular Haulers i'd say you've got a pretty good set up. Don't know what to tell you on the -2, i've never ridden a shee in the sand with one. I would imagine it would be fun though.... Quote Link to comment Share on other sites More sharing options...
ledofthezep Posted February 17, 2005 Report Share Posted February 17, 2005 Pretty much what OR said...suits my style. I like to ride technical shit, tight trails, through trees & shit, and I like to air it out here & there. It's very predictable when airborne now & I feel like I have more control over both the banshee & my fate. It's all good, there's nothing better than a banshee in the sand no matter how long or short it is. If possible, try both & see what you think for yourself. Currently I'm running the same gearing I ran with my stock arm: 13:41. That is soon to be changed & is wwwwwaaaaayyy overdue, I'm probably going to go up to a 15 in the front, may come down a tooth in the back...not quite sure yet. It's still much better than before eventhough my gearing has been neglected since I've had my -2 arm. Quote Link to comment Share on other sites More sharing options...
Justintoxicated Posted February 17, 2005 Report Share Posted February 17, 2005 (edited) thats the whole fun with a 13 tooth! just lean forward more...lol leaning forward will help alot of course... getting a -2 will make your problem worse Getting a +2 will help alot. Do not get a -2 for sand, if anything run stock over a -2 you will have better controll. I'll tell you that most of your problem is from the 10 paddle haulers. that is WAY to much paddle for a stock/piped banshee, especialy with a stock swingarm!. They will make you wheelie like crazy and slow you down at WOT. I would not like your setup at all...Your problem is probably alot worse when running the haulers huh? you could put the Sand Stars on and get a +2 swingarm and that will help you keep the front end down. Your gearing is also affected by tire size, Trouble with switching to a 14 tooth is that you have too much paddle for a 14 tooth... Better setup is some 7-8 paddle extremes (Probably 7 if your mostly stock) 20-10-10, +2 or +4 swinger (its a bit long at +4 for duing vs drag racing) and keep the 13 onthe front so you can pull 4th gear up the steep side of olds (maybe you can pull it with a 14 on the front but probably won't be going as fast) When you change the length of the Swinger, you also have to have your shock re-valved for the length of the swingarm and your weight. I recomened a place like TCS to do this service. it makes all the difference in the world. The Advantage of running a -2 in the sand is that you will wheelie like a MoFo! Edited February 18, 2005 by Justintoxicated Quote Link to comment Share on other sites More sharing options...
