doltz Posted February 15, 2005 Report Share Posted February 15, 2005 All riight boys its time to take the shee to the next level! I want a duneable quad with good ice,dirt & sand drag capabilities. My current mods are below. Ques. 1. I am upgrading to a 4mm stroker 370cc what size carb is usually used? 2.I currently run T5 pipes .Will they be fine with the new motor upgrades ? (CPI's will come later). 3.What intake should I run? 3. 4" or 6" ext. swingarm (I run 20 x 10 X10 9 paddle Hauler Extremes) Curr. mods Hot Rod Crank .040 Vitos pistons Noss Head 20cc domes Mid Port job (not drag) T5's Cut fly wheel +4 timing plate K & N's V Force Reeds Barnett clutch Quote Link to comment Share on other sites More sharing options...
richybanshee Posted February 15, 2005 Report Share Posted February 15, 2005 Checkout this info before you do any more upgrades to your shee: From A&S Racing http://www.bansheeracing.com/cheetahcub.htm also: From PaatriotRacing http://www.patriotracing.net/Cheetah%20Cub.htm T5 pipes are okay with any mod, CPI's will get more ponies out of does mods. Quote Link to comment Share on other sites More sharing options...
Southside Motorsports Posted February 15, 2005 Report Share Posted February 15, 2005 get a set of UPP intakes...they work the best. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted February 16, 2005 Report Share Posted February 16, 2005 generally no less than 34 or 35mm carbs. i would recommend 35mm pwk with a boss intake. you might also wanna check into those cheetah cub cylinders. they are supposed to be pretty badass but im still waiting on more dyno sheets..t5s will be fine for now but cpis or rockets will pull alot more power from that engine. who is doing your engine work?? Quote Link to comment Share on other sites More sharing options...
Southside Motorsports Posted February 16, 2005 Report Share Posted February 16, 2005 No performance is gained by a billet intake....only looks, same thing with a boost bottle. they are both gimmicks to take your money.. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted February 16, 2005 Report Share Posted February 16, 2005 No performance is gained by a billet intake....only looks, same thing with a boost bottle. they are both gimmicks to take your money.. 324108[/snapback] did i say they helped you gain performance? i hope thats not what you are implying. how much are upp intakes? for a little more money id rather just have the bling... Quote Link to comment Share on other sites More sharing options...
stclark816 Posted February 16, 2005 Report Share Posted February 16, 2005 No performance is gained by a billet intake....only looks, same thing with a boost bottle. they are both gimmicks to take your money.. 324108[/snapback] I could be wrong.. But whole really notices a big performance increase with a certain kind of intake? Quote Link to comment Share on other sites More sharing options...
Southside Motorsports Posted February 16, 2005 Report Share Posted February 16, 2005 I wasn't implying that you said they did, just adding some info. Quote Link to comment Share on other sites More sharing options...
doltz Posted February 16, 2005 Author Report Share Posted February 16, 2005 Thanks I think I am going with the Cheetah Cub wit 34 PJ's. A&S is going to hook me up. Quote Link to comment Share on other sites More sharing options...
