Guest FastShee Posted February 12, 2005 Report Share Posted February 12, 2005 At the dunes do you have to reduce the tire pressure of the stock tire. What is the acutall pressure and to what pressure do you have to decrease. Quote Link to comment Share on other sites More sharing options...
ikikazz Posted February 12, 2005 Report Share Posted February 12, 2005 At the dunes do you have to reduce the tire pressure of the stock tire. What is the acutall pressure and to what pressure do you have to decrease. 321973[/snapback] get new ones... stock tires suck in the dunes, if you lose your momentum you are fucked... Quote Link to comment Share on other sites More sharing options...
Guest FastShee Posted February 12, 2005 Report Share Posted February 12, 2005 get new ones... stock tires suck in the dunes, if you lose your momentum you are fucked... 321974[/snapback] They sure do suck. I think the stock is like 4 psi. Shall I reduce it to 1 psi. Quote Link to comment Share on other sites More sharing options...
00BANSHEE Posted February 12, 2005 Report Share Posted February 12, 2005 my .02 1 psi is not a good idea. You might roll the tire off the rim. I would stay around 3-4 psi. Quote Link to comment Share on other sites More sharing options...
kw04 Posted February 12, 2005 Report Share Posted February 12, 2005 the stock tires suck in any condition Quote Link to comment Share on other sites More sharing options...
ikikazz Posted February 12, 2005 Report Share Posted February 12, 2005 the stock tires suck in any condition 322085[/snapback] ya id say keep them at 4-5 because 1psi all you will do is pop it off the bead... just go out and have fun that is all that matters Quote Link to comment Share on other sites More sharing options...
05bansh Posted February 13, 2005 Report Share Posted February 13, 2005 Get yourself some Skat Trak Haulers, run about 4lbs psi. You'll be good to go! Quote Link to comment Share on other sites More sharing options...
John19 Posted February 14, 2005 Report Share Posted February 14, 2005 Get yourself some Skat Trak Haulers, run about 4lbs psi. You'll be good to go! 322546[/snapback] I wouldn't use the stock tires anywhere! Quote Link to comment Share on other sites More sharing options...
