05Special Posted February 10, 2005 Report Share Posted February 10, 2005 anybody see an advantage to having these, or are they a waste of money Quote Link to comment Share on other sites More sharing options...
Cotton eyed Joe Posted February 10, 2005 Report Share Posted February 10, 2005 anybody see an advantage to having these, or are they a waste of money 320578[/snapback] Alot of people use them between the reed block and the carbs instead of between the reed block and the cylinders to space the carbs back a bit if they are using larger bore carbs. This keeps the clutch lever arm from wearing through the bowl. Quote Link to comment Share on other sites More sharing options...
ledofthezep Posted February 10, 2005 Report Share Posted February 10, 2005 Alot of people use them between the reed block and the carbs instead of between the reed block and the cylinders to space the carbs back a bit if they are using larger bore carbs. This keeps the clutch lever arm from wearing through the bowl. 320588[/snapback] Interesting. I know of a guy who completely removed the reed blocks, installed boyseen reeds with spacers, his powerband comes on smooth, not like a lightswitch anymore. I've pondered doing this myself...Anyone else here run without the blocks? Quote Link to comment Share on other sites More sharing options...
Justintoxicated Posted February 10, 2005 Report Share Posted February 10, 2005 Interesting. I know of a guy who completely removed the reed blocks, installed boyseen reeds with spacers, his powerband comes on smooth, not like a lightswitch anymore. I've pondered doing this myself...Anyone else here run without the blocks? 320996[/snapback] WTH is a Reed Block? All I have is a Reed Cage, Manifold, and Carb. You are refering to putting them between the reed and the manifold I think? To move the carb away from the clutch cable arm. I got my Carbs used and the bolt was ground down on the bottem to clear the arm without any expensive spacers. (anyone else feel these are ridiculously expensive for what you get?) Only trouble is I have to remove 4 screws to remove the bottem of the left carb rather than the uhh 14mm? on the bottem. So it is liek jetting stock carbs on that side, only it is still easier cause no TORS. Quote Link to comment Share on other sites More sharing options...
ledofthezep Posted February 10, 2005 Report Share Posted February 10, 2005 WTH is a Reed Block? Sorry...in 'yamaha terms' it is called a ...STOPPER, REED VALVE The little metal brakets that keep the reeds from opening all the way up. Quote Link to comment Share on other sites More sharing options...
64xracer Posted February 11, 2005 Report Share Posted February 11, 2005 Sorry...in 'yamaha terms' it is called a ...STOPPER, REED VALVE The little metal brakets that keep the reeds from opening all the way up. 321019[/snapback] Yeah I took mine off about a year ago when I installed boysen power reeds and I have'nt had any problems reeds still look good. Not gonna use them anymore cause I scored a set of v-force off of e-bay for $50!!!! Quote Link to comment Share on other sites More sharing options...
23champ Posted February 11, 2005 Report Share Posted February 11, 2005 Interesting. I know of a guy who completely removed the reed blocks, installed boyseen reeds with spacers, his powerband comes on smooth, not like a lightswitch anymore. I've pondered doing this myself...Anyone else here run without the blocks? 320996[/snapback] boyseen is a dual stage reed. The reed blocks are not needed any longer with the boyseen kit. Quote Link to comment Share on other sites More sharing options...
ledofthezep Posted February 11, 2005 Report Share Posted February 11, 2005 Yeah I took mine off about a year ago when I installed boysen power reeds and I have'nt had any problems reeds still look good. Not gonna use them anymore cause I scored a set of v-force off of e-bay for $50!!!! 321115[/snapback] You suck! boyseen is a dual stage reed. The reed blocks are not needed any longer with the boyseen kit. 321134[/snapback] I love the HQ. Learn something new all the time. Quote Link to comment Share on other sites More sharing options...
rocketboy Posted February 12, 2005 Report Share Posted February 12, 2005 i run a 3/8 billet reed spacer with vforce2 and ive tried it without spacer,for my setup the spacer made a noticable difference,from my experianve the spacer is a great mod for high performance applications not very noticable on mostly stock she ,i have a smooth powerful hit ,without it on pavement the power is erratic and wheels are never on the ground cant control steering at all,my.02 Quote Link to comment Share on other sites More sharing options...
00BANSHEE Posted February 12, 2005 Report Share Posted February 12, 2005 I have a set of 1/2" billet reed spacers with hardware I'll sell for $20 shipped. Quote Link to comment Share on other sites More sharing options...
GYTWYPT Posted February 12, 2005 Report Share Posted February 12, 2005 I took the stops off not long after i purchased my she about 10 years ago. I lived in Cali and a dirtbiker buddy of mine just took an old set of reeds cut them in half and put them on my reeds. Worked real good. That is just a cheap way. Quote Link to comment Share on other sites More sharing options...
