BRIAN BANSHEE Posted February 9, 2005 Report Share Posted February 9, 2005 ive never heard of it does n e one have n e pics of what it is. Quote Link to comment Share on other sites More sharing options...
fixitrod Posted February 9, 2005 Report Share Posted February 9, 2005 If you go to meats web page http://www.thebansheezone.com/Bansheezone/clutchstator.htm You'll see a pic of it. It is what your shift shaft ( the thing you use your foot to shift) grabs to change gears. It has little post on it that need to be lined up in the center of the shift shaft claws. It's the star shaped item lower just left of center. Quote Link to comment Share on other sites More sharing options...
BRIAN BANSHEE Posted February 9, 2005 Author Report Share Posted February 9, 2005 and whats the benefit of replacing it? Quote Link to comment Share on other sites More sharing options...
hamuel Posted February 9, 2005 Report Share Posted February 9, 2005 Have you ever in your life heard of a banshee with neutral between first and second gear? personly i had never seen one with it. while warm. WEll there was that day when i had the cash for the boon tune!. He modifed the shiftstar. The little points were as tall. And Guess what NEUTRAL DOES EXIST!!! IT REALY DOES!!!!!!. Then the fact that the lightened fly wheel just made the bike that much easyer to ride!. I high recommend it! a moded shiftstar would be the 5 thing i did to a brand new bike. Quote Link to comment Share on other sites More sharing options...
PUSH THE THROTTLE Posted February 9, 2005 Report Share Posted February 9, 2005 If you get one that has been modified it makes it easier to locate neutral and some also take the high spots off the "points" to make it shift smoother. Quote Link to comment Share on other sites More sharing options...
boonman Posted February 10, 2005 Report Share Posted February 10, 2005 You will gain quicker, more precise shifts. And lose the missed shifts and the times when it goes "in-between" gears, and hangs up. Unless you bend a shift fork. Anyways, you will also be able to find neutral in a snap. A modded star with the neutral detent cut back is a Godsend for the times when you need to find neutral with the bike still running. You will like it. Now, you can mod the star yourself on a bench grinder. BUT, you will need a milling machine and a carbide endmill to machine the neutral detent back. The shift star is harder than a Bulls' #@$* if you know what I mean. I have heard of people grinding the neutral detent with a dremel, but for the minimal cost, I would highly suggest having it dne right. A die grinder cannot size the detent properly, and let the cam roller sit the way it should... Quote Link to comment Share on other sites More sharing options...
GYTWYPT Posted February 12, 2005 Report Share Posted February 12, 2005 (edited) where can we have this mod done? Does anyone have a good pic of a moded shift star? Edited February 12, 2005 by GYTWYPT Quote Link to comment Share on other sites More sharing options...
Meat Posted February 12, 2005 Report Share Posted February 12, 2005 where can we have this mod done? Contact "Boonman". He's the resident shift star modder Quote Link to comment Share on other sites More sharing options...
boonman Posted February 14, 2005 Report Share Posted February 14, 2005 Click ME to go to B370's page on this. There is some pics on there. Quote Link to comment Share on other sites More sharing options...
