jake_bayless Posted February 8, 2005 Report Share Posted February 8, 2005 I just got a set of FMF SST's put on and the head shaved to up the compression to 150 psi and and air box mod. I got everything jetted in correct. went rideing sat. and i had more bottem end power when it was stock I was wanting a little more bottem end than stock that is the main reason i shaved the head but it didnt help so i am confused was I right or wrong that if you shave the head it helps out on bottem end torch But when the power does hit it hits "HARD" and strong Quote Link to comment Share on other sites More sharing options...
dlnoss Posted February 8, 2005 Report Share Posted February 8, 2005 Was just the base of the head shaved or was it re-chambered? It should have improved the bottom end unless it was rechambered. Quote Link to comment Share on other sites More sharing options...
jake_bayless Posted February 8, 2005 Author Report Share Posted February 8, 2005 the head was just shaved i think it was 40 thousandths Quote Link to comment Share on other sites More sharing options...
DBLtapS Posted February 8, 2005 Report Share Posted February 8, 2005 where do you ride, whats the temp, elevation, and your jet settings? I thought I had my jetting right too until, I talked to someone who knew what they were talking about. I was sizes too big on my main and one too small on my pilots.... Any other mods? Quote Link to comment Share on other sites More sharing options...
