Why is he faster?
01CandyBlue
THANKS FOR THE INFO RICHYBANSHEE. I WILL SACRIFICE WINNING IN A DRAG FOR BEING ABLE TO RIDE COMFORTABLE THROUGH THE DUNES. MAYBE THE ANSWER IS FOR MIKE AND I TO STROKE OURS AND KEEP THE POWER IN THE LOW END. I DON'T KNOW ABOUT MIKE BUT I NEED MY BIKE TO STAY A LITTLE BIT ALL PURPOSE. HEY MIKE DON'T DO THAT 15 TOOTH SPROCKET AT LEAST NOT WITH THE TEN PADDLES MAYBE IT WOULD WORK BETTER WITH THE EIGHTS. REMEMBER HOW MINE RAN WITH THE HIGH GEARS. YOUR GEARS ARE ALRIGHT.
You won't be able to pull 10 paddles very well with stock bore/stroke. A banshee relies on wheel spin and doesn't like to be lugged around. You should be able to pull 9 paddle haulers but even then you might not be as fast as you would with 8 paddles. Also I'd get the reeds ASAP...since you've got some porting your stock reeds are definately holding you back. A stock shee might gain 2-3 horses from a set of v-force, but a ported shee could be 3x that easily.
