rear sprocket
1800bigk
yep.....the spark energy is where you get the advantage of the ignition.....with a big motor like these you need specific setup stuff....I don't want to take a chance of it not having enough timing or having too much....I know it makes power with it at stock curve with a 4 degree and is safe running, no detonation or piston burning.
A 38 WILL throw the chain. Ask Daren :( . Luckily he was just testing it to see if it would break and not full throttle on that Cheetah. I think he is still mad at me for letting him borrow that sprocket.
The stock curve is about the best on the dyna box. I run a program with 3 degrees advance across the board. This is on my 4mm Passion motor on gas. My alky 4mm will probably be different.
enFORCER, I'll give you a hand installing that engine. I need to see what I might be up against later this year. Are you all going to come down and play on the pavement with Daren and I?
  • 1 year later...
