what the fuck
kotin6
I took my head completly off nothing wrong there. took my case back off, gears are fine, waterpumps fine. I cant find the problem. My buddie told me that i may need more octaine in my fuel and it could be causing a predetination. Im have 20cc domes im at sealevel and its about 60 degreese. Ideas anyone. for reference see also What the fuck in this same section.
Why would you tear into the motor if you have no fire - it is an electrical problem not a mechanical problem.
But like a lot of people said on your last post the stator and CDI go bad more often then the coil - try a stator and CDI off of a friends bike if you can to see which is no good. I also bought a new coil but found out after it was the CDI that was bad.
But if your using 20cc domes at sealevel you probably need race gas - I run 21cc domes at sealevel and i'm at the limit for compression with pump gas. But this would have nothing to do with you not having fire.
Edited by Tim C
