Compression
Well I just checked it and I have about 90psi in both cylinders. I am sending the cylinders off to Eric Gorr to have a woods port job done. I am going to rebuild the motor before I put it back together. Do you think that will fix my problem? If not what should I do? What should my compression be when I am all said and done?
Thanks Travis
Are there rings on the pistons??? Just kidding. That is really low. I'd be suspicious of the compression tester if it was done correctly. I'm surprised it will kick start with the compression that low.
With a fresh top end when you get it back it will improve. Ask Gorr what to expect with 20cc domes and his porting.....something over 140.
