trialsallday Posted January 26, 2005 Report Share Posted January 26, 2005 which one should i get for recreational use any draw backs to the 4+1? Quote Link to comment Share on other sites More sharing options...
bansheefreak Posted January 26, 2005 Report Share Posted January 26, 2005 i think 4+1 is like a stock wheel they recommend them if you have wide arms... so if you trail ride i think the 4+1 would be good chioce... Quote Link to comment Share on other sites More sharing options...
wantinashee Posted January 27, 2005 Report Share Posted January 27, 2005 if i remember right the stock wheel ofset on a banshee is 3:2, and i think hyper only makes that offset for the yamaha bolt pattern. Quote Link to comment Share on other sites More sharing options...
sredish Posted January 27, 2005 Report Share Posted January 27, 2005 Stock offset is 3-2. A 4-1 is good if your wanting to narrow the machine a bit. For instance, I'm running +2 arms in XC/ Woods and use the 4-1 when I need a narrower track and my 2-3's when it's opened up. On a side note - I don't believe Hiper is currently making a front wheel in a 4-1 offset with a Yamaha pattern. This was recently discussed on another forum, Quadzone.com, that is moslty a quad racing site. Later. Quote Link to comment Share on other sites More sharing options...
trialsallday Posted January 29, 2005 Author Report Share Posted January 29, 2005 thanks guys. i just bot brand new razr's front and rear and im gonna get my hipers tonight probably Quote Link to comment Share on other sites More sharing options...
checkster Posted January 30, 2005 Report Share Posted January 30, 2005 wouldnt it be easier if they just used "backspacing" like on car wheels? so if stock is 3-2 that means what? is it 3" on the back and 2" on the front? or the other way around? check Quote Link to comment Share on other sites More sharing options...
sredish Posted January 30, 2005 Report Share Posted January 30, 2005 thanks guys. i just bot brand new razr's front and rear and im gonna get my hipers tonight probably 313895[/snapback] If your running stock a-arms, the 3-2 offset is fine. If your +2 a-arms , then I'd consider getting another brand and getting a 4-1 offset. The 4-1 will handle a tad better, it won't be too wide for the trails and will help out a lot with bumpsteer. The reason is, it puts the centerline of the wheel directly over the ball joints so the bump is transferred straight above the spindle, where as a more offset wheel its transferred outside of the spindle and tries to kick the tire more. Post some pics when you get em. Scott Quote Link to comment Share on other sites More sharing options...
