bansheewizard Posted January 23, 2005 Report Share Posted January 23, 2005 yes i know it has not a thing to do with a banshee but on my new yfz450 when it gets hot the pipe turns bright bright red what is the problem??? thanks Quote Link to comment Share on other sites More sharing options...
blueshee03 Posted January 23, 2005 Report Share Posted January 23, 2005 thats easy.its a four stroke.to fix it is even easier.trade it on a two stroke.lol Quote Link to comment Share on other sites More sharing options...
triple B Posted January 23, 2005 Report Share Posted January 23, 2005 you could be running lean did you change the jetting at all? you can burn valves that way Quote Link to comment Share on other sites More sharing options...
FIRST BANSHEE Posted January 23, 2005 Report Share Posted January 23, 2005 yes i know it has not a thing to do with a banshee but on my new yfz450 when it gets hot the pipe turns bright bright red what is the problem??? thanks 310516[/snapback] The problem is you only make power 1 out of 4 revolutions causing your pipe to be imbarressed... seriously is it running good, if the choke isn't working properly it could cause an overrich condition, causing the pipe to turn red. have you done any mods. Quote Link to comment Share on other sites More sharing options...
blueshee03 Posted January 23, 2005 Report Share Posted January 23, 2005 your timing aint to far advanced is it? Quote Link to comment Share on other sites More sharing options...
bansheewizard Posted January 23, 2005 Author Report Share Posted January 23, 2005 hahah ive got a 2stroke still and the yfz is 1 day old now the only thing is the spark aresster is out?? Quote Link to comment Share on other sites More sharing options...
rocketboy Posted January 23, 2005 Report Share Posted January 23, 2005 The problem is you only make power 1 out of 4 revolutions causing your pipe to be imbarressed... hahahah true dat Quote Link to comment Share on other sites More sharing options...
Nighty Posted January 23, 2005 Report Share Posted January 23, 2005 They come lean from the factory. Try the dadog yfz450 page they have lots of good information. But dont do the cam mod since its bullcrap and will destroy your engine. Quote Link to comment Share on other sites More sharing options...
WAKEBOARDDAVE1 Posted January 23, 2005 Report Share Posted January 23, 2005 yes i know it has not a thing to do with a banshee but on my new yfz450 when it gets hot the pipe turns bright bright red what is the problem??? thanks 310516[/snapback] I HAVE A BANSHEE NOW BUT I HAD A RAPTOR BEFORE I HAD STAINLESS PIPES ON IT AND IT TURNED RED TOO U COULD ONLY NOTICE IT AT NIGHT WHEN I WAS IDLEING I ASKED AROUND AND WAS TOLD THATS OK AS LONG AS YOUR JETTED RIGHT DO A PLUG TEST AND IF NEEDED REJET Quote Link to comment Share on other sites More sharing options...
