bansheeryder21 Posted January 18, 2005 Report Share Posted January 18, 2005 How much more power will a cooled head give you than milled head? Which do you prefer? I know cooled head is more $$$! Is the power worth the $$$? Help me out! Quote Link to comment Share on other sites More sharing options...
jeenyus Posted January 18, 2005 Report Share Posted January 18, 2005 you gain power by adding compression, milled head or cool head (with dome of your choice for the compression you want) is the same thing... but a milled head do not have the cooling benefit Quote Link to comment Share on other sites More sharing options...
SICK BOY Posted January 18, 2005 Report Share Posted January 18, 2005 Both are better then stock,but if you can afford it go with a cool/Noss head. Quote Link to comment Share on other sites More sharing options...
H250RHATER Posted January 18, 2005 Report Share Posted January 18, 2005 lets put it this way if u go w/ a milled head u can never put compresion to a lower level if u go w/ a cool or noss head u can raise or lower the compression to what ever setting u prefer for compression level Quote Link to comment Share on other sites More sharing options...
jake_bayless Posted January 19, 2005 Report Share Posted January 19, 2005 i am having my head shaved right now because i am not going over 150psi but if you are planning on going over 150 to 160 go with a cool head because the stock head isnt made to withstand that presure the cool head will make the motor a lil cooler but i personally dont think it is worth it when you can shave the head and put an inline cooler in the radator hose and get the same benifit just my opinion hope this helps Quote Link to comment Share on other sites More sharing options...
