1800bigk Posted January 17, 2005 Report Share Posted January 17, 2005 Check this chart out http://www.trinityracing.com/pages/jetting...heejetting.html The chart says engines with a stage 4 port job and twin 35mm carbs, the main jet should be at or near 165, and if you look at the bottom of the chart it says a 500cc engine with stage 4 port w/35mm carbs main jet 158. Is this correct? How come alot of people on here have port jobs and 35's but are running main jets well into the 170's. I know all bikes are different but thats a big difference isnt it. thanks Quote Link to comment Share on other sites More sharing options...
Banchetta Posted January 17, 2005 Report Share Posted January 17, 2005 Depends on porting, elevation, temp., and different carbs. I ran 162 mains in the pwk carbs, but run a 175 in the pj carbs... Quote Link to comment Share on other sites More sharing options...
RNBRAD Posted January 17, 2005 Report Share Posted January 17, 2005 I think it is of coarse a ball park figure. I run 160 mains, 55 pilots, cel needles mid clip, 600 ft elevation for 70 to 90 degree temps. This is on dual 35's with stage 4 porting and pipes. I actually don't see very many people running the dual 35 pwk's. Seems like more use the pj's to me. Quote Link to comment Share on other sites More sharing options...
1800bigk Posted January 17, 2005 Author Report Share Posted January 17, 2005 So I take it there is a big jetting difference between pj 34 and pwk 35 on the exact same engine. Quote Link to comment Share on other sites More sharing options...
Banchetta Posted January 17, 2005 Report Share Posted January 17, 2005 So I take it there is a big jetting difference between pj 34 and pwk 35 on the exact same engine. 307777[/snapback] I had 162 mains, 42 pilots and 2nd clip on the needles w/ pwks.....same mods, different carbs, put 34pj's on and went to a 175 mains, 55-58pilots, needle 5th clip and still wants more....went to a shorter needle and still wants more fuel...Tried a CGL, then CGK, CGJ, CEJ, now a DEJ...ya, totally different. Quote Link to comment Share on other sites More sharing options...
1800bigk Posted January 17, 2005 Author Report Share Posted January 17, 2005 ok thanks, can the pj 34 support similar horsepower levels as the pwk 35? For instance, trinity says the 400cc cheetah kit needs 35pwk, but could pj 34 do just as good or do I need that extra one milimeter? tia Quote Link to comment Share on other sites More sharing options...
night rider Posted January 17, 2005 Report Share Posted January 17, 2005 ok thanks, can the pj 34 support similar horsepower levels as the pwk 35? For instance, trinity says the 400cc cheetah kit needs 35pwk, but could pj 34 do just as good or do I need that extra one milimeter? tia 307784[/snapback] dude don't pay no att to the web site I talked to a guy at Trinity and he said do not lisgen to the web site a web geek wrote it go with what feels good and looks good on the plug Quote Link to comment Share on other sites More sharing options...
night rider Posted January 17, 2005 Report Share Posted January 17, 2005 34 pj's will wosk fine a friend of mine had the kit years before me he has a 34 pj I have a 35 pwk we have the same work done and run the same same jetting so I don't see the diff. hope this helps Quote Link to comment Share on other sites More sharing options...
1800bigk Posted January 17, 2005 Author Report Share Posted January 17, 2005 good info thanks Quote Link to comment Share on other sites More sharing options...
Banchetta Posted January 18, 2005 Report Share Posted January 18, 2005 34's are supposed to be better for bottom end response while the 35's are supposed to be better for top end...very minimal on a dyno if any... Night rider, you both have the same jetting?? What are you running?? Quote Link to comment Share on other sites More sharing options...
rocketpig Posted January 18, 2005 Report Share Posted January 18, 2005 dude don't pay no att to the web site I talked to a guy at Trinity and he said do not lisgen to the web site a web geek wrote it go with what feels good and looks good on the plug 307867[/snapback] Hahahahahah!!!! I wrote it! ... Using a chart supplied by the owner, that is. Quote Link to comment Share on other sites More sharing options...
Nighty Posted January 18, 2005 Report Share Posted January 18, 2005 sweet... well the site is cool. great design. Quote Link to comment Share on other sites More sharing options...
rocketpig Posted January 19, 2005 Report Share Posted January 19, 2005 sweet... well the site is cool. great design. 308445[/snapback] Thanks, it's a never ending project... There's always a need for new stuff but unfortunately, I don't get enough time to get all the things I would like added up on the site. Quote Link to comment Share on other sites More sharing options...
sredish Posted January 19, 2005 Report Share Posted January 19, 2005 trinity jetting chart., is it accurate? There is NO chart that is accurate or right on. And while it may be for one bike, it won't be for the next. All bikes jet a little different. They all like different things in different areas. NO ONE can tell you what jet you will need or use! EVERYTHING is a guideline that will have to be tested and verified and in most cases adjusted per the machine. Remember that, and you will be fine. That goes with jetting charts, jet kits, the little jets that come with pipe kits and everything. (I'm sure that was said, but I don't feel like going through all those posts right now.) Quote Link to comment Share on other sites More sharing options...
banshee76179 Posted January 20, 2005 Report Share Posted January 20, 2005 There is NO chart that is accurate or right on. And while it may be for one bike, it won't be for the next. All bikes jet a little different. They all like different things in different areas. NO ONE can tell you what jet you will need or use! EVERYTHING is a guideline that will have to be tested and verified and in most cases adjusted per the machine. Remember that, and you will be fine. That goes with jetting charts, jet kits, the little jets that come with pipe kits and everything. (I'm sure that was said, but I don't feel like going through all those posts right now.) 309001[/snapback] Word! Quote Link to comment Share on other sites More sharing options...
