1800bigk Posted January 14, 2005 Report Share Posted January 14, 2005 (edited) Is it ? Edited February 13, 2005 by 1800bigk Quote Link to comment Share on other sites More sharing options...
SDD Posted January 14, 2005 Report Share Posted January 14, 2005 You probably can't make that on gas with a stock stroke or big bore. It would take at least a 7mm stroker to do that on gas with stock cylinders. You might get close if you use alky and a little nitro mixed in or NO2. A cheetah cylinder will get into the 90's on gas. Quote Link to comment Share on other sites More sharing options...
Southside Motorsports Posted January 14, 2005 Report Share Posted January 14, 2005 yes, you will get around 90-95 hp out of a 400 cheetah on gas with a full drag setup. Quote Link to comment Share on other sites More sharing options...
Big Blue Posted January 15, 2005 Report Share Posted January 15, 2005 with a cheetah kit yes, stock cylinders on gas no, might me able to get into the 80hp range on gass with a 4mm. Quote Link to comment Share on other sites More sharing options...
Southside Motorsports Posted January 15, 2005 Report Share Posted January 15, 2005 exactly...I know of guys that have made around 79-83 hp on gas with a 4mm stock cylinder motor. Quote Link to comment Share on other sites More sharing options...
Big Blue Posted January 18, 2005 Report Share Posted January 18, 2005 If you are willing to wait here is a new setup that will be out shortly The new cheetah cub http://www.bansheeracing.com/ Read this thread as well http://www.planetsand.com/ubbthreads/showf...o=&fpart=1&vc=1 Quote Link to comment Share on other sites More sharing options...
Forcefed Posted February 2, 2005 Report Share Posted February 2, 2005 (edited) It IS absolutely possible and has allready been done....many moons ago...... 89 RWHP and 49.6 ft/lbs Torque 350 - Stock cylinders - on Gas - 54mm crank - 4.1`s in 300ft with 180lb rider - stock chassis. Edited February 2, 2005 by Forcefed Quote Link to comment Share on other sites More sharing options...
blueshee03 Posted February 3, 2005 Report Share Posted February 3, 2005 i think its possible but hard to do.i run a motor that is all stock except for a big reed conversion,mild port work ,milled head,toomey pipes and 34pj's and at the time they dynoed it it was putting out around 82 hp on gas. Quote Link to comment Share on other sites More sharing options...
1800bigk Posted February 3, 2005 Author Report Share Posted February 3, 2005 wow those are some nice numbers Quote Link to comment Share on other sites More sharing options...
Forcefed Posted February 3, 2005 Report Share Posted February 3, 2005 wow those are some nice numbers 316536[/snapback] Thanks....wonder what kind of #`s the bike was puttin down when it was being sprayed this summer ? ....not that #`s really matter at all anyways..... Quote Link to comment Share on other sites More sharing options...
23champ Posted February 11, 2005 Report Share Posted February 11, 2005 Jeff Weindorff of Fast Racing has a 350 drag motor on alky that has put out 98hp several times on the dyno. probably somewhere around high 80's to 90 on gas. Race Gas that is. Quote Link to comment Share on other sites More sharing options...
