1800bigk Posted December 30, 2004 Report Share Posted December 30, 2004 I just got my 34 pj's in the mail today and I notice that they are huge compared to the stockers. I am still waiting for my manifold from Passion. My question is do I have to trim anything from the stock air box to get these to fit. I know there wasnt much room with the stock carbs before, so I'm guessing some modification has to be done. I was also wondering about the clutch, is that clutch thing going to hit the left carb float bowl? My manifold wont be here until monday so I cant go install everything yet, I was just eyeballing things. Any input from someone who has done this would be greatly appreciated. Once again the set up is, 34 pj's, passion intake manifold, upp boots, stock air box. TIA Quote Link to comment Share on other sites More sharing options...
sheefreak Posted December 30, 2004 Report Share Posted December 30, 2004 Bump Quote Link to comment Share on other sites More sharing options...
fixitrod Posted December 30, 2004 Report Share Posted December 30, 2004 You'll have to move the airbox back. You can zip tie it in place. We've all done our own rig jobs. If you have acess to a welder, you could cut the rear mounting tabs off and move them back. You can bend the clutch part down if it rubs the bowl. Quote Link to comment Share on other sites More sharing options...
1800bigk Posted December 30, 2004 Author Report Share Posted December 30, 2004 (edited) damn, I was hoping to get buy with some cutting cause i have that coolnat bottle back there so if i move the air box back the coolant wont line up with its hole now i gotta rig the coolant bottle, man its one thing after another. Edited December 30, 2004 by 1800bigk Quote Link to comment Share on other sites More sharing options...
fixitrod Posted December 30, 2004 Report Share Posted December 30, 2004 http://kuoi.asui.uidaho.edu/~john/tips.html Click that. It'll show you how to move the bottle up front. It's the best coolant upgrade I've every made. Quote Link to comment Share on other sites More sharing options...
1800bigk Posted December 30, 2004 Author Report Share Posted December 30, 2004 great, since i have it apart i might as well relocate that coolant bottle, thanks Quote Link to comment Share on other sites More sharing options...
Ducman Posted December 30, 2004 Report Share Posted December 30, 2004 My 34mm mikunis fit on the airbox in the stock location with a bilit manifold but it was virgin pussy tight. It probably wouod have helped a lot to trim 1/2" off the air box runners. I wen't to foam pod filters, made life sooo much easier, jetting goes way quicker, and a $15 bracket to relocate the bottle. Bend the clutch arm a little if needed and possibly file a little bit off of the hex nut on the botom of the carb if needed. I think the boss manifold is supposed to be angled to help big carbs clear the clutch arm so you'll probably be ok. Quote Link to comment Share on other sites More sharing options...
Banchetta Posted December 31, 2004 Report Share Posted December 31, 2004 I just notched my rear fenders a little so the coolant bottle can go back. I bent my rear tabs for the air box back and no longer use the front ones. Works fine. I also had to cut some of the front of the air box where the boots go on. I left just enough for the boots to clamp onto, then I had to cut the boots to shorten them up...you'll see when you get the manifolds...Like Rod said, we all have our rigs... Quote Link to comment Share on other sites More sharing options...
PassionRE Posted January 1, 2005 Report Share Posted January 1, 2005 (edited) If you cut down some 2 inch rubber plumbing adaptors, you can pretty much leave the box in place. I prefer to run at least 2.5 inch rubber couplers in length on back of the bigger carbs when box is being used..in that case, you can zip-tie the box in place and it works fine. The intake you ordered will let even the biggest carbs clear the clutch arm with ease....Jim Edited January 1, 2005 by PassionRE Quote Link to comment Share on other sites More sharing options...
stclark816 Posted January 1, 2005 Report Share Posted January 1, 2005 great, since i have it apart i might as well relocate that coolant bottle, thanks 299888[/snapback] Who needs a coolant bottle?? Quote Link to comment Share on other sites More sharing options...
1800bigk Posted January 1, 2005 Author Report Share Posted January 1, 2005 sweet, I cant wait to put this beast back together, thanks for all the replies. Quote Link to comment Share on other sites More sharing options...
Blue Duece Posted January 1, 2005 Report Share Posted January 1, 2005 If you cut down some 2 inch rubber plumbing adaptors, you can pretty much leave the box in place. I prefer to run at least 2.5 inch rubber couplers in length on back of the bigger carbs when box is being used..in that case, you can zip-tie the box in place and it works fine. The intake you ordered will let even the biggest carbs clear the clutch arm with ease....Jim 300415[/snapback] damm that looks familar...... Quote Link to comment Share on other sites More sharing options...
bogart Posted January 4, 2005 Report Share Posted January 4, 2005 Who needs a coolant bottle?? 300427[/snapback] yea thats what someone else said.i tryed it all it does it leak Quote Link to comment Share on other sites More sharing options...
