Bansheeman1121 Posted December 28, 2004 Report Share Posted December 28, 2004 whats wrong when the pipes turn red and sparks shoot out of my silencers?? long story held wide open in the snow. Should i let it be or do i gotta tear it down?? Quote Link to comment Share on other sites More sharing options...
01bansheefox Posted December 28, 2004 Report Share Posted December 28, 2004 I have no clue at all but done they have some type of packing inside? Maybe it needs replaced. just my thoughts Quote Link to comment Share on other sites More sharing options...
zilladude Posted December 29, 2004 Report Share Posted December 29, 2004 Sounds like it is too lean. Sparks could be carbon or piston material. Quote Link to comment Share on other sites More sharing options...
Banchetta Posted December 29, 2004 Report Share Posted December 29, 2004 Sounds lean to me also, what size jets are your running? Quote Link to comment Share on other sites More sharing options...
fixitrod Posted December 29, 2004 Report Share Posted December 29, 2004 Yep, the weather got cold and you didn't jet up. Is it a banshee? The stock yfz are know for that. They come a little lean. Header pipe will turn bright red.....not good. Quote Link to comment Share on other sites More sharing options...
Justintoxicated Posted December 29, 2004 Report Share Posted December 29, 2004 Yep, the weather got cold and you didn't jet up. Is it a banshee? The stock yfz are know for that. They come a little lean. Header pipe will turn bright red.....not good. 299133[/snapback] I thought that was how you could tell when it's warmed up! no need for a temp gauge Quote Link to comment Share on other sites More sharing options...
Cotton eyed Joe Posted December 29, 2004 Report Share Posted December 29, 2004 I thought that was how you could tell when it's warmed up! no need for a temp gauge 299167[/snapback] Tie a cheese dog to it, and when it squirts out one end, its time to eat, then ride. Quote Link to comment Share on other sites More sharing options...
Bansheeman1121 Posted December 29, 2004 Author Report Share Posted December 29, 2004 So no big deal?? just jet up?? Could it be i ran ngk 9s in it?? My pistons not fried?? I left it at my friends house so ill juat take the roads back nice and easy Quote Link to comment Share on other sites More sharing options...
Banchetta Posted December 30, 2004 Report Share Posted December 30, 2004 Just look at the plugs. If you see sparkly silver specs, then thats detonation. Don't ride it. If not, then you should be fine. Buy a compression tester and check your compression, that'll give you peace and mind and let you know where you stand. You should have one anyways. They only cost $20-50...Go back to B8ES. The 9's are just cooler.. Quote Link to comment Share on other sites More sharing options...
