ALLABOUTTHEBANSH Posted December 24, 2004 Report Share Posted December 24, 2004 Planin to go ridin for 3-4 days with some mates in 2 days time and hav'n problem gettin shee to run right...Problem is when i start it up and hold it at a constant RPM it bogs down and backfires and will die out if u dont keep rapin it on to get the revs back up...It will do this hot or cold and it is also has a problem hitting powerband at WOT... I have removed and cleaned Tank,fuel cock,fuel lines,A/filter and both carbs... Have replaced the plugs also Any help would be appreciated Quote Link to comment Share on other sites More sharing options...
05bansh Posted December 24, 2004 Report Share Posted December 24, 2004 What size jets are you running? Mains, pilots, and where is the clip on your needle at? Definately sounds like a jetting issue. Quote Link to comment Share on other sites More sharing options...
ALLABOUTTHEBANSH Posted December 24, 2004 Author Report Share Posted December 24, 2004 What size jets are you running? Mains, pilots, and where is the clip on your needle at? Definately sounds like a jetting issue. 297218[/snapback] Not sure of sizes but ive been ridin this thing with no probs for a year now and all of a sudden from one ride to the next it started this What about the TORS...Maybe i need to disconnect??? Quote Link to comment Share on other sites More sharing options...
ledofthezep Posted December 24, 2004 Report Share Posted December 24, 2004 I'd definately try d/c the torrs, unplug the box under the front left part of the tank, if you have a clymers it will show you where. Other than that, sounds like a toasted stator to me. Quote Link to comment Share on other sites More sharing options...
fixitrod Posted December 27, 2004 Report Share Posted December 27, 2004 (edited) I agree with led. I've seen stator cause goof problems like that too. I'd make sure all the circuits in the carbs are clean first. How does it start? Edited December 27, 2004 by fixitrod Quote Link to comment Share on other sites More sharing options...
Toomey Banshee Posted December 27, 2004 Report Share Posted December 27, 2004 Unplug your tors and parking brake, clean and sync your carbs and see how that does. Quote Link to comment Share on other sites More sharing options...
H250RHATER Posted December 27, 2004 Report Share Posted December 27, 2004 also check ur reeds one of them could have broke Quote Link to comment Share on other sites More sharing options...
