I just bought a used dyna ignition and was wondering if you can use it with regular spark plugs and such?
296219[/snapback]
How do you like it so far? NGK BR8 make sure they are the resistor type plugs.
Yes u can run the b8es spark plugs with the dyna ignition. I have the same ignition, I called them up and asked if i had to run the resister spark plugs with it. They said no, just gives a tiny bit more spark and wont hurt anything if u dont run the resister plug.
