kdneo Posted December 10, 2004 Report Share Posted December 10, 2004 Just got my bike back out of the shop. When filling the radiator up, how full do I fill it??? Right now I can look down in the radiator and see where the fins start. Should I be able to see fluid??? Also is there any special type of coolant that you have to use or just a 50/50 mix??? Quote Link to comment Share on other sites More sharing options...
sheefreak Posted December 10, 2004 Report Share Posted December 10, 2004 (edited) Engine ice is about the best coolant for your quad, if not just make sure you mix distilled water with the 50/50 mix. radiator should be full, just pay attention to your reservoir and fill it up a little at a time as you see the level go down(level in reservoir) Eventually it will stay pretty much at a constant level. Edited December 10, 2004 by sheefreak Quote Link to comment Share on other sites More sharing options...
blk02banshee Posted December 10, 2004 Report Share Posted December 10, 2004 50/50 mix is fine, but it should be up to the bottom of the filler neck. you'll have to run it for a bit with the cap off, to get all the air bubbles out. Quote Link to comment Share on other sites More sharing options...
superbanshee03 Posted December 10, 2004 Report Share Posted December 10, 2004 50/50 with any anti freeze is fine, and just pour it full and crank the motor and watch the coolent you should be able to see it through the top or your radiator, let it run for a little while and make sure it stays full, if it goes down a little just add some more Quote Link to comment Share on other sites More sharing options...
kdneo Posted December 10, 2004 Author Report Share Posted December 10, 2004 awesome, thanks for the early morning help guys!!!!! Quote Link to comment Share on other sites More sharing options...
