Holyman Posted December 3, 2004 Report Share Posted December 3, 2004 I finally got a round carrier like I always wanted with the tapered bearings. But I am going to need a billet axle nut. I've seen them go anywhere from $10 to $80. Is there one that's better than the others? Quote Link to comment Share on other sites More sharing options...
Banshee~ Posted December 3, 2004 Report Share Posted December 3, 2004 I think david makes some Quote Link to comment Share on other sites More sharing options...
Holyman Posted December 3, 2004 Author Report Share Posted December 3, 2004 I think david makes some 288519[/snapback] David Noss? Quote Link to comment Share on other sites More sharing options...
NYUK Posted December 3, 2004 Report Share Posted December 3, 2004 I think david makes some 288519[/snapback] David Noss? 288523[/snapback] alloy secialties are nice too. them parts were sent out wed morn holy. Quote Link to comment Share on other sites More sharing options...
dlnoss Posted December 3, 2004 Report Share Posted December 3, 2004 Before I bought a CNC Lathe, I farmed turning work out and had a bunch of these made. I'd sell them to BHQ members for $30 each + shipping. They have a 4130 ring on the inside so the aluminum won't get chewed up. Quote Link to comment Share on other sites More sharing options...
Holyman Posted December 4, 2004 Author Report Share Posted December 4, 2004 4130 ring for what? Are the threads 4130? Does it have 1 lock bolt or 2? Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted December 4, 2004 Report Share Posted December 4, 2004 me and my brother both have one of noss's locknuts and so far they work excellent. no problems whatsoever Quote Link to comment Share on other sites More sharing options...
dlnoss Posted December 4, 2004 Report Share Posted December 4, 2004 The 4130 ring is on the 'pressure' surface since the aluminum is relatively soft. It has one bolt. Quote Link to comment Share on other sites More sharing options...
SICK BOY Posted December 4, 2004 Report Share Posted December 4, 2004 I had a RAD single lock one,intill I got my DuraBlue axle and I had no problems with it.I sold it to Fro and I think he's still using it. Quote Link to comment Share on other sites More sharing options...
SDD Posted December 5, 2004 Report Share Posted December 5, 2004 I like the stainless steel one Duncan racing makes. I just don't like the price. Quote Link to comment Share on other sites More sharing options...
Meat Posted December 5, 2004 Report Share Posted December 5, 2004 (edited) Here's my experience, take it for what its worth... but I had one of those alloyspecialties locknuts and couldnt keep the focker tight. Your not supposed to tork em down against the sprocket hub so tight that you bind up the axle, according to alloy specialties directions. You gotta get the nut tight enough so the sprocket hub won't rock back and forth on the axle splines, but loose enough that it doesnt bind the axle. Your supposed to lift the ass end off the ground and the axle should spin freely and the sprocket hub is nice and tight on the splines. Easy enough.............. then one day I notice my sprocket hub moves back and forth on the splines... just a little play.... but it wasnt cool. So I loosen the two allen heads on the axle nut and it turns in pretty good, stopped the sprocket hub from rockin' and the axle spinnin' freely. Check it again in a few week and same thing happens. Sprocket hub loose on the splines. So I re-tighten it again and wrap electrical tape on the axle threads at the axle nut. POS came loose again. I took it off and put on a LoneStar nut and havent had a problem since. The LSR nut is built similar to the Alloy Specalites nut... I don't know why I had problems with the AS nut, but its not my problem anymore, I sold it on Ebay a few months ago. FYI, Im using a LSR axle, and a billet LSR sprocket hub. Edited December 5, 2004 by Meat Quote Link to comment Share on other sites More sharing options...
