CPI too loud?!
wickedSS
i'm at the same dilemma, same place, with my T5s. the suggestion was to use stock silencers with them. You may have to cut and weld but that will quiet them down past the 94dB range and give you the spark molesters that they require also. Not sure how they'll fit with your CPI's but with the right facilities and ambition you could get the stockers onto them probably.
The Cascade CFX silencers work with the CPI's and lowering your db's are what they are designed for. Cehck 'em out. They were made to be a fix for Banshee owners that had to meet Oregon's dune sound requirements, but then allow you you to not have to purchase another brand of pipe. They make them for quite a few bikes now.
Clicky Cliky
:cheers:
I wouldnt worry to much about them. Theres usually a ton of bikes louder then my cpi's here at the Oregon Dunes and when you see a cop just go the other way. Sometimes you have to sit in the parking lot and wait for the sherrif to leave but he's usally got his eye on someone else anyway. I think the piped 4 strokes are a lot louder then the CPI's so there shouldnt be much of a problem.
I run a set of old old answer silencers and have found a way to nig-rig them to just about every pipe I own. They are quiet 95db and I don't notice any loss of power between those and the silencers that came with my sst's. Maybe a little tiny bit, but nothing I am going to sit around and bitch about for the noise level.
I am in MI too!!!
They are pretty strict about arresters but noise, I am runnin CPI inframes and pass the test at 97db. State law is 95 but they let 98 into the park thank god.And that was with home made sparkys
