Speaking of skid plates!
dogboystoy
A few years ago I made my underbelly (under the motor) myself, out of alluminum (3/16"). Anyway., The only way I could figuire to mount them was to use 2 U bolts in the front, and I drilled 4 holes in the gussetts under the motor area (you know,, where the frame joins and these little corner supports are welded in.. But now after some time the bolt holes I made are stripping out and the skid plate rattles a little. I was thinking about drilling completely through the rest of the gussett and throwing a nut under there but, If I recall correctly it is a little tight under the motor for 4 nuts.
Any opinions?
