I know this iss off topic but i need UR OPINIONS
Hi there i havent been on here in a while i been workin alot for the new make over for my shee this winter. But lets get to my question i have a 1990 Ford F-250 Pick up truck long bed, bench seat... ( my parents got this for me for a first car thinkin i would wreck something nice ) well i bought 3 10" Subwoofers in special desighned boxes for then to go behind the seat. Now this is a single bench seat cab i was wandering wut POSITION would i get the best BASS sound out of the truck??? BASS SPEAKERS FACING SEAT OR THE BACK STEEL WALL? some say it will muffle on seat some say its better on the wall let me kno wut u tihnk??? please i need to kno wut would be the best befor i start this project??? thanks alot guys..... :notworthy:
Really depends... just mount them each way and drive around for a bit and test them out. I had some subs in my ranger... faced them backwards and they sounded better... where as my original sub I had facing forward. Really depends on the box in my opinion.
You get most of the sound from the voice coil at the back of the sub... whereas your reverberation (sp?) comes from the cone itself. The box affects both. If the box's material is thin... then you'll get more of the sound from the voice coil than if it was thicker.
Ported boxes, band pass, and sealed all have factors as well.
Ported = increased air flow inside of box... deeper bass sound, less hit and crispness
Band pass = pressure added to both sides of woofer... crispest bass, hardest hit, lighter tone
Sealed = pressure to back side of woofer... crisp bass, hard hit, good tone.
SOunds just about right, I would face them to the wall...You will get more bass out of them. What type of tens are you running and what Type of amp? Im currently running three 12" alphasoniks and a 3000 watt amp on the bass and a 1000 on the voice.
284390[/snapback]
I had 4 10" W6's in the cab of my F150 firing downward and it hit hard. I also ran 6 10's downward in my Toyota and it hit even harder. The ones in the toyota were Kickers and in the Ford were JL Audio. Both boxes were sealed. If you cant mount them firing down then mount them facing forward but take the back of the seat off. That way it gives them a little more air room. No matter what you do you cant win any DB drags in a standard cab pickup there just isnt enough air room. Good Luck
284377[/snapback]
dont face them toward the back!!thats a bad thing cus it will rattle annoyingly. face them foward or if you have enough space put them under the seat facing up or down. doesnt really matter but if you face them down they will possibly rattle the cab which will end up further costing you money to buy dyna mat which is like sound wave absorbant and will mostly stop any rattles.
I would put some sound dampening material on the back wall of the cab if I were
you. I have heard that the cone should be at least half the diameter away from
any reflective surface (5" for a 10sub). The seat back is not really reflective
but the rear of the cab is somewhat. A sound check is in order in both directions
because it is subjective to a lot of variables. Stripping the interior and dampening every surface with spray on and stick on dampening materials is money and time well spent. When properly done, the sound quality that can be achieved far surpasses that of the same system in a non-dampened vehicle.
284898[/snapback]
ive never heard that before, but it makes a ton of sense. i have heard in ported boxes you need to be at least the port's width from the nearest object though.
