fixitrod Posted November 22, 2004 Report Share Posted November 22, 2004 (edited) $33 Crimp tool $60 Wire $10 nic card You alread have a router which you can just build a crossover cable for one device too. $60 wireless router $20 wireless ethernet card Or since you have a router $10 nic card (circuit city) $60 for a cable (I'd buy a pre made cable for sure) But, for $10 nore you can have wireless. I'd go that route for sure. Edited November 22, 2004 by fixitrod Quote Link to comment Share on other sites More sharing options...
fixitrod Posted November 22, 2004 Report Share Posted November 22, 2004 Okay, I did some research for you. Check it out. $50 for wireless eithernet after rebates. http://www.circuitcity.com/ssm/Belkin-Wire...roductDetail.do http://www.circuitcity.com/ssm/Belkin-Wire...roductDetail.do Quote Link to comment Share on other sites More sharing options...
racer Posted November 22, 2004 Author Report Share Posted November 22, 2004 very true fixit, but then id have to redo my other computer and the PS2 to wireless as well. other point is that in college the dorms and most of the aptartments have rj45 connections in the wall. so im going to put a wired ethernet card in the computer regardless. Quote Link to comment Share on other sites More sharing options...
racer Posted November 22, 2004 Author Report Share Posted November 22, 2004 in your 11:02 post, do you mean that i could run the wireless router off of my wired router so i dont have to reo the other stuff? Quote Link to comment Share on other sites More sharing options...
fixitrod Posted November 22, 2004 Report Share Posted November 22, 2004 in your 11:02 post, do you mean that i could run the wireless router off of my wired router so i dont have to reo the other stuff? 283758[/snapback] No, but you can. That's the beauty of ethernet. Quote Link to comment Share on other sites More sharing options...
racer Posted November 22, 2004 Author Report Share Posted November 22, 2004 in your 11:02 post, do you mean that i could run the wireless router off of my wired router so i dont have to reo the other stuff? 283758[/snapback] No, but you can. That's the beauty of ethernet. 283759[/snapback] the gears in my head are starting to work. ok fixit got another one for ya. what should i do about some ram for this boat anchor. its got 64mb now, but id like 256. should i take it apart, remove the current ram and match it up at bestbuy or try to get the codes off of fit? Quote Link to comment Share on other sites More sharing options...
fixitrod Posted November 22, 2004 Report Share Posted November 22, 2004 in your 11:02 post, do you mean that i could run the wireless router off of my wired router so i dont have to reo the other stuff? 283758[/snapback] No, but you can. That's the beauty of ethernet. 283759[/snapback] the gears in my head are starting to work. ok fixit got another one for ya. what should i do about some ram for this boat anchor. its got 64mb now, but id like 256. should i take it apart, remove the current ram and match it up at bestbuy or try to get the codes off of fit? 283764[/snapback] You just need to know what kind of ram you are using. Most ram now days doesn't need to be matched. Try to find out what kind of motherboard you have and I can help you out there too. Most like it sdram and won't need another 64mb. You're motherboard will probably only except up to 256mb per slot of sdram but maybe only 128mb and most likely not ddr if it's from 2000. If it's one of the major brand pc's they may still be able to tell you what you have without charging you if you call. You definitly want more than 64mb. What processor are you running? I ask because it might be more worth your money upgrade to another cpu with a faster buss speed depending on what you are doing. Quote Link to comment Share on other sites More sharing options...
racer Posted November 22, 2004 Author Report Share Posted November 22, 2004 mostly word processing. its an intel celeron 633mhz. i could probably get out the manual and hopefully it would tell me whats in it. when i said match it up i meant match up the types. Quote Link to comment Share on other sites More sharing options...
fixitrod Posted November 22, 2004 Report Share Posted November 22, 2004 mostly word processing. its an intel celeron 633mhz. i could probably get out the manual and hopefully it would tell me whats in it. when i said match it up i meant match up the types. 283776[/snapback] Yeah, you can just get the same type in a 256mb stick. Then try it with both chips in it. You still want to see what the max capacity is per slot though. I believe that most of those boards would be a max of 256mb with 100mhz front side buss. I'd have to look it up though. Quote Link to comment Share on other sites More sharing options...
racer Posted November 22, 2004 Author Report Share Posted November 22, 2004 kick ass, guess ill just take it apart tonight and see what i can do. it could probably use to be blown out iwth some air also. Quote Link to comment Share on other sites More sharing options...
fixitrod Posted November 22, 2004 Report Share Posted November 22, 2004 Look on the motherboard for some identifying numbers and a brand. Get online and do a search. You'll most likely be able to find some specs. Some boards were two slotted with 256mb system max. Quote Link to comment Share on other sites More sharing options...
racer Posted November 22, 2004 Author Report Share Posted November 22, 2004 cool, gracias dude, im out. Quote Link to comment Share on other sites More sharing options...
racer Posted November 23, 2004 Author Report Share Posted November 23, 2004 the ram was PC 100. dont know what it means but hey, it works. thing loads programs almost as fast as my 04 computer. the 512mb 2.4ghz one. now for the ethernet card and router. ill bum that money offa the parents, cause hey its for college. thanks for the help rodney. Quote Link to comment Share on other sites More sharing options...
fixitrod Posted November 24, 2004 Report Share Posted November 24, 2004 PC100 is 100mhz sdram. Quote Link to comment Share on other sites More sharing options...
