recomp Posted November 22, 2004 Report Share Posted November 22, 2004 Hi, I just wanted to get an idea of what some of you use for your sprocket sizes? 12/40 or 13/41 or 12/38 I am doing alot of jumps and some MX racing. thanks Quote Link to comment Share on other sites More sharing options...
txblueshee Posted November 22, 2004 Report Share Posted November 22, 2004 15/41 with 20'' tires Mike Quote Link to comment Share on other sites More sharing options...
recomp Posted November 22, 2004 Author Report Share Posted November 22, 2004 15/41 with 20'' tires Mike 283563[/snapback] I was thinking 12/36. I was using a 13/40 setup, then i broke the front sprocket. when I went to get a new one all they had was a 12. I put that on and it is real great, but i lost my top end. So i was thinking of going to a 12/36 setup to get it back to what it was. I do like the take off power of the 12 tooth. thanks for your input. George Quote Link to comment Share on other sites More sharing options...
fixitrod Posted November 22, 2004 Report Share Posted November 22, 2004 15/41 with 20'' tires Mike 283563[/snapback] Same here, but I'm also running a ported stroker with 190psi. I have bottom end like crazy. I do need to gear up though becasue I break free to much coming out of the corners. Quote Link to comment Share on other sites More sharing options...
racer Posted November 22, 2004 Report Share Posted November 22, 2004 i dont know if you can run a 36 can you? i though the sprocket carrier's size came into play some where when you startedrunning those smaller cogs. Quote Link to comment Share on other sites More sharing options...
tats4life Posted November 22, 2004 Report Share Posted November 22, 2004 smallest you can run on a banshee hub is 39 without hitting the sprocket hub. I run 16/38 or 16/39 with a honda hub and 18 in. tires. Quote Link to comment Share on other sites More sharing options...
txblueshee Posted November 22, 2004 Report Share Posted November 22, 2004 15/41 with 20'' tires Mike 283563[/snapback] I was thinking 12/36. I was using a 13/40 setup, then i broke the front sprocket. when I went to get a new one all they had was a 12. I put that on and it is real great, but i lost my top end. So i was thinking of going to a 12/36 setup to get it back to what it was. I do like the take off power of the 12 tooth. thanks for your input. George 283675[/snapback] I don't know why you wanna run tractor gears in the 'shee.... you'll get leg pump from shifting so fuckin much. Run a tall gear and the 4-strokes don't have a prair in the straights. Mike Quote Link to comment Share on other sites More sharing options...
yanks5164 Posted November 23, 2004 Report Share Posted November 23, 2004 i run 15/41 and thing im gonna go up a tooth in the rear for a lil more bottom im also running 18 Quote Link to comment Share on other sites More sharing options...
sredish Posted November 23, 2004 Report Share Posted November 23, 2004 I run a 10/56 and it's perfect! Quote Link to comment Share on other sites More sharing options...
limitied03 Posted December 3, 2004 Report Share Posted December 3, 2004 I'm running 15/41 with 18 inch tires and i love it on the track Quote Link to comment Share on other sites More sharing options...
superbanshee03 Posted December 3, 2004 Report Share Posted December 3, 2004 I run 15/41 with 18" tires and its perfect with my setup. Quote Link to comment Share on other sites More sharing options...
