Flyin_Shee Posted November 19, 2004 Report Share Posted November 19, 2004 (edited) On January 24th I will be doing a radar run on Lake Washington in Minnesota and I am going to need to make sure I have the best gearing for the quarter mile. I am running FMF Fatty pipes and Powercore II silencers and ordering PWK30mm carbs. I MIGHT be adding Pro Design cool heads and 21cc domes to it later on and maybe even V-Force 2 reeds, or 3 if I can get them for a good price. Can someone tell me what is THE best sprocket set up for the 1/4. I will be running 20" tires on HiPer rims with ice screws and studs. The studs will probably be around 1-2 inches long. Thanks in advance. Also, right now I am running one tooth smaller than stock (13 I believe) and it's definately way too low for my liking, I don't even think I can hit the powerband in any gear. Feels almost like a Blaster . What is the stock gearing? Edited November 19, 2004 by Flyin_Shee Quote Link to comment Share on other sites More sharing options...
Flyin_Shee Posted November 20, 2004 Author Report Share Posted November 20, 2004 Anyone? Quote Link to comment Share on other sites More sharing options...
badcompany Posted November 22, 2004 Report Share Posted November 22, 2004 id say around 15-41 Quote Link to comment Share on other sites More sharing options...
Flyin_Shee Posted November 22, 2004 Author Report Share Posted November 22, 2004 Alright thanks, is 14/41 the stock gearing then? Quote Link to comment Share on other sites More sharing options...
badcompany Posted November 22, 2004 Report Share Posted November 22, 2004 i think 14/41 is stock. I might even go 16/41 or 15/39, are u going to be able to test and tune? Quote Link to comment Share on other sites More sharing options...
Southside Motorsports Posted November 27, 2004 Report Share Posted November 27, 2004 If it was me i would definitely run a taller tire than a 20. Quote Link to comment Share on other sites More sharing options...
red ore Posted November 27, 2004 Report Share Posted November 27, 2004 On January 24th I will be doing a radar run on Lake Washington in Minnesota and I am going to need to make sure I have the best gearing for the quarter mile. I am running FMF Fatty pipes and Powercore II silencers and ordering PWK30mm carbs. I MIGHT be adding Pro Design cool heads and 21cc domes to it later on and maybe even V-Force 2 reeds, or 3 if I can get them for a good price. Can someone tell me what is THE best sprocket set up for the 1/4. I will be running 20" tires on HiPer rims with ice screws and studs. The studs will probably be around 1-2 inches long. Thanks in advance. Also, right now I am running one tooth smaller than stock (13 I believe) and it's definately way too low for my liking, I don't even think I can hit the powerband in any gear. Feels almost like a Blaster . What is the stock gearing? 282669[/snapback] most radar runs I have been to run 1000 feet, not a 1/4 mile. Its only cutting off 320 fett, but thats alot when your reved out. gear it up some, but in with the mods you have now, it will be hard to pull a really high gear. or just come up here and try this... CLICK HERE~~>>ice racing<<~~~CLICK HERE Quote Link to comment Share on other sites More sharing options...
banshee76179 Posted November 28, 2004 Report Share Posted November 28, 2004 In 1/8th mile drag strip I'm @ the middle to top of 5th w/18x10x10 hossiers,gearing 15/41 If U R running a complete 1/4 1320 , if u r running a 20" tire u need at least 16 maybe even a 17 front sprocket 41 rear... Quote Link to comment Share on other sites More sharing options...
Flyin_Shee Posted November 28, 2004 Author Report Share Posted November 28, 2004 (edited) I would run a taller tire but I'm tight on money, so 20" will have to do. My 30mm carbs should be coming in sometime this next week, or next. What reeds should I get? Boyeson or V-Force and what's a good place to order them from? I might also order a Pro Design Cool Head w/ 21cc domes (so I can still run pump gas). As long as I have the Banshee torn apart right now, are there any companies that sell an aftermarket shift star for easier shifts? And where is the cheapest place to get a good port? Also, I might be able to have test time with gearing...all depending on when I order my mods and if I order any more mods besides my 30mm carbs. Edited November 28, 2004 by Flyin_Shee Quote Link to comment Share on other sites More sharing options...
