jeenyus Posted November 16, 2004 Report Share Posted November 16, 2004 i know that i have to rejet, i have no lid mods except the litlle neck removed, main jet 240, pilot stock. is 240 to 260 OK? and what about pilot and oil? THX Quote Link to comment Share on other sites More sharing options...
BradDaMan Posted November 16, 2004 Report Share Posted November 16, 2004 (edited) i know that i have to rejet, i have no lid mods except the litlle neck removed, main jet 240, pilot stock. is 240 to 260 OK? and what about pilot and oil? THX 281337[/snapback] I would remove the lid and start with a 320 main and leave the rest of the carb alone. But will depend on where your at. Edited November 16, 2004 by BradDaMan Quote Link to comment Share on other sites More sharing options...
BdBanshee Posted November 16, 2004 Report Share Posted November 16, 2004 If all you did is remove the snorkel off of the airbox lid, then you shouldn't have to rejet. Quote Link to comment Share on other sites More sharing options...
jeenyus Posted November 16, 2004 Author Report Share Posted November 16, 2004 i have to rejet, yesterday i started my shee and let it warm up, after 2min, i put my hand at the end of the silencer to check if my engine run perfect... it wasnt !! one cylinder is running faster than the other. (pe-POW, pe-POW...) in the owner book, they say to rejet 2 size bigger if the temperature is under 0degree, so if im 240 ( maybe some people says that its is too small jettin, my shee runs perfect, no hesitation, no bug...) i should go to 260?? and maybe ill remove the lid cover, so is 280 should be OK? im 700 feet above the sea level. Jee' THX Quote Link to comment Share on other sites More sharing options...
BdBanshee Posted November 17, 2004 Report Share Posted November 17, 2004 Don't remove the air box lid unless you attach the airfilter to the box, unless you buy a Noss or Prodesign airbox plenum. If you remove the lid and run without doing this you will suck in dirt/sand and ruin your topend. Quote Link to comment Share on other sites More sharing options...
jeenyus Posted November 18, 2004 Author Report Share Posted November 18, 2004 it is attached to the airbox, i have an adaptor plate Quote Link to comment Share on other sites More sharing options...
