fixitrod Posted November 14, 2004 Report Share Posted November 14, 2004 I need a bearing for my angle grinder. All I have are the demisions... no numbers. It's a off brand cheapo and they didn't even use a bearing in the head. Just so metal bushing but a high speed bearing would make it run even better. Outer race 1.260" Inner race .489 Thickness .387 Now these demisions are what I measured. If theres something out there just slightly different let me know. I'll double check my measurements. Rodney Quote Link to comment Share on other sites More sharing options...
SICK BOY Posted November 14, 2004 Report Share Posted November 14, 2004 (edited) PM Holyman,he should be able to get them.If not check out CLICK That place is by me so if they have it and won't ship it to you,I'll pick it up and mail it to you. Edited November 14, 2004 by SICK BOY Quote Link to comment Share on other sites More sharing options...
boonman Posted November 14, 2004 Report Share Posted November 14, 2004 I will check my bearing manuals at work tomorrow, but it appears that you have a wierd bearing. The O.D. kind of seems like a 32mm, but the id specs at 12.4mm by your measurements???? Thickness is close to 10. And how is it shielded? Rubber seals? Or steel shields? z Quote Link to comment Share on other sites More sharing options...
2004LEBanshee Posted November 14, 2004 Report Share Posted November 14, 2004 (edited) try Timkin http://www.timken.com/ Edited November 15, 2004 by 2004LEBanshee Quote Link to comment Share on other sites More sharing options...
fixitrod Posted November 15, 2004 Author Report Share Posted November 15, 2004 There currently is no bearing in there. It's a cheap ass grinder. They put an insert with a hole and that's it. It last a little while. It got so much slop in it the gears don't mess right now. If I put a bearing in there it'll last a lot better. Boonman, that 10mm 12mm 32mm might work. I seen that on another site too but I didn't want to order a pack of 10..lol. Quote Link to comment Share on other sites More sharing options...
fixitrod Posted November 15, 2004 Author Report Share Posted November 15, 2004 Here's a part number I think might work if I could just get 1 instead of 10 at a time. 6201-2rs It's rated at 15,000rpms. It's 32mm outside, 12mm bore and 10mm thick. Quote Link to comment Share on other sites More sharing options...
fixitrod Posted November 15, 2004 Author Report Share Posted November 15, 2004 I found one locally for 2.90. If somebody doesn't have a free one I'll go pic that one up tomorrow. Quote Link to comment Share on other sites More sharing options...
