PolyKarbon Posted November 13, 2004 Report Share Posted November 13, 2004 Sorry, this is also posted in images. The plugs aren't really all that shiney in real life, but thay are definitly black all around, with mild carbon build up (not that much). Please help, I have no idea how to jet even though I've read all the post on it. Also, the bike idles too high, and when I give it just a slight touch of throttle, she bogs down, and if I hold the throttle just wee little bit open, like a few millimeters, she dies on me. What the hell do I do? NGK plugs, bpr7ES. FMF gold series 2 pipes. Boyeson rad valve reeds, wiseco pistons, mild bore, pro design air filter. Thanks. Quote Link to comment Share on other sites More sharing options...
banshee76179 Posted November 13, 2004 Report Share Posted November 13, 2004 Need to go down a size on the pilots and adjust the clip,and air screw.. Quote Link to comment Share on other sites More sharing options...
Screamin_Banshee Posted November 13, 2004 Report Share Posted November 13, 2004 looks rich. any reason for the 7 plugs, instead of 8's? Quote Link to comment Share on other sites More sharing options...
PolyKarbon Posted November 13, 2004 Author Report Share Posted November 13, 2004 The guy who bored them said the bigger cylinders needed the hotter plugs. Quote Link to comment Share on other sites More sharing options...
nickxc Posted November 13, 2004 Report Share Posted November 13, 2004 not a problem man, no one knows how to jet when they are born. its easy once you get it. your air screw and pilot jet control the idle - 1/8 throttle, from roughtly 1/8 to 3/4 is controlled by your needle clip position and your needle jet(usually you dont have to change a needle jet) and 3/4 to full throttle is controlled by the size of your main jet. figure out where your problem is and that is what you have to change. you said just off idle it dies so I would see if you are way too right on your pilot. try adjusting your airscrew, then go to the needle and see if that is causeing the problem, are those plugs from a WOT stop or are they just riding and looking like that... They are way rich by the looks but a rich condition in one circuit can hide a lein condition in another so you have to make sure you are rich all over and not just way way rich on the mains and lein on something else. look for a post by benbb and check out the "unofficial bansheehq jetting faq" click on that. it has everything you want to know about jeting a banshee... if you have any other problems check out everything2stroke.com They are great and will help you out and you can pm me of you want me to explain anything better to you. pm me here or on everything2stroke. im on both sites about everyday... Quote Link to comment Share on other sites More sharing options...
