flywheel
You need to buy the flywheel puller made just for the banshee. I think magic racing has them if you cant get one locally.
280096[/snapback]
Exactly, buy the thread in style puller for the Banshee. It has a left hand thread that screws into the flywheel, and then a push bolt that threads thru the center of the puller and pushes on the crank.
thanks guys and its on the side with the stator right
280168[/snapback]
That's right, the stator is underneath the flywheel.
If you have an air, or electric impact you won't need the strap wrench. Impact is the easiest and fastest way to remove it.
I have used the impact method on Banshees a few times and it worked great. But just a few weeks ago, I had a problem doing this on a blaster. Using the puller with an impact caused the end of the crack to squish out so that it was a little shorter and fatter on the end. To put the bike back together, I had to grind the end of the crank down in order to put the nut on. If it would have dammaged it just a little more, I would have been buying a crank.
You have been warned!
