WITCH PIPE?
glamisrat
I HAVE A 87 BANSHEE .040 OVER , PORTED STAGE 4,HEAD MODIFIED FOR 165 PSI. TRINITY 2 INTO 1 WITH 34PJ CARB,DYNA IGNITION,200WATT STATOR WITH ADJ TIMMING,DELTA REEDS
I HAVE TOOMY T5 PIPES BUT I CAN TRADE FOR FMF FATTYS
WITCH WOULD BE BEST FOR THIS SET-UP?
Hell, I loved my Fatties in the sand. Great pipes right there, the T5s are also great pipes. So, it's a tough decision, they both actually produce similar power on the dyno, similar curves and all, main difference is the T5s come on about 900rpm later and fall off about 900rpm later.
do you have the link to that dyno chart?
Yea, those colors are hard to see unless you make it fullsize, which is big. The banshee is a 370LR with porting. Don't know the size of carbs off hand, can't remember actually.
Click HERE for the torque sheet This new look makes it hard to see links.
Edited by sredish
