warwgn Posted November 3, 2004 Report Share Posted November 3, 2004 how do you test a cdi to see if it is good, or can it be tested other than plugging it up and try to start it????? Quote Link to comment Share on other sites More sharing options...
banshee76179 Posted November 3, 2004 Report Share Posted November 3, 2004 Do U know it's the CDI??? What the prob.?? I would say if U r certain Find a buddy and take his off of his bike and try that... other than that I'm for sure there is a way to test it... try and do a search for Benbb he has a eletrical trouble shooting faq. I believe. Chris Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted November 3, 2004 Report Share Posted November 3, 2004 You local dealership can test the CDI for free. My dealership here in Laramie, WY tested my CDI. Took like 2 min to do, and they didn't charge me for it. Quote Link to comment Share on other sites More sharing options...
tats4life Posted November 3, 2004 Report Share Posted November 3, 2004 You local dealership can test the CDI for free. My dealership here in Laramie, WY tested my CDI. Took like 2 min to do, and they didn't charge me for it. how the hell did they test your cdi? i work at a dealer and there is no real way to test a cdi....you cah ohm it out and do resistance test but that doesnt' prove shit. Quote Link to comment Share on other sites More sharing options...
NYUK Posted November 3, 2004 Report Share Posted November 3, 2004 plug yours into a running banshee, do any of your friends own a banshee?i have owned at least 40 banshees and have never had a bad cdi.it does happen. but it s usually the stator ,coil or a bad connection before a cdi. Quote Link to comment Share on other sites More sharing options...
KRMit Posted November 3, 2004 Report Share Posted November 3, 2004 plug yours into a running banshee, do any of your friends own a banshee?i have owned at least 40 banshees and have never had a bad cdi.it does happen. but it s usually the stator ,coil or a bad connection before a cdi. I've owned 1 Banshee and had a CDI go out. Quote Link to comment Share on other sites More sharing options...
BenBB Posted November 3, 2004 Report Share Posted November 3, 2004 CDI on my Banshee went out once too...but warwgn has a Raptor... Dustin, as far as I know the only way to test the CDI 100% sure is to swap in a known working one. When mine went out I got a Dyna becuase it was alot cheaper than OEM, but that may not be the case anymore. Have you tested everything else? What happened on the spark plug cap, try a new one yet?? Unless you've ruled out everything else it could be something as simple as wires grounding against the frame or each other (Chris mentioned you had some wire trouble), I'd make sure it wasn't something else before getting a new CDI... Quote Link to comment Share on other sites More sharing options...
