theredscout Posted November 2, 2004 Report Share Posted November 2, 2004 I have a 2001 Banshee with considerable mods done to it including a 5mm stroker. The engine was professionally built by white knuckle racing and has been rock solid. My problem is I have absolutely NO bottom end. I know with the banshee I shouldn't expect much Torque but my buddies banshee that is simply piped and jetted is much easier to ride than mine. Once my Shee warms up I really have to work the clutch to stay in the power. I jump on my buddies and one slip of the clutch and the power is right there. Don't get me wrong when we race I blow him away but only in a straight line. I recently had it dyno tuned and was impressed with the numbers....73hp..just NO and I mean NO bottom end. Any suggestions???? Quote Link to comment Share on other sites More sharing options...
dlnoss Posted November 2, 2004 Report Share Posted November 2, 2004 One thing I have seen a few times is excessive squish clearance, particularly when the stock head is used with a top spacer plate sandwiched between two head gaskets. This may not be how yours is set up. Quote Link to comment Share on other sites More sharing options...
lucky13 Posted November 2, 2004 Report Share Posted November 2, 2004 what do you got for pipes and carbs Quote Link to comment Share on other sites More sharing options...
rebelbanshee2 Posted November 2, 2004 Report Share Posted November 2, 2004 was the porting adjusted for the stroke? if its just a plate at the bottom with no porting adjustment then that might be the problem. Quote Link to comment Share on other sites More sharing options...
theredscout Posted November 2, 2004 Author Report Share Posted November 2, 2004 I am running the stock carbs but they have been taper bored. Porting was also done by white knuckle at the time of the stroker install. I am still running the stock reeds but he modified them. I am going to add the V-force reeds in the coming weeks in hopes of helping the bottom end out a bit. Any other suggestions?? Quote Link to comment Share on other sites More sharing options...
01bansheeke Posted November 2, 2004 Report Share Posted November 2, 2004 build another motor Quote Link to comment Share on other sites More sharing options...
broke Posted November 2, 2004 Report Share Posted November 2, 2004 build another motor That isn't very nice. Quote Link to comment Share on other sites More sharing options...
dlnoss Posted November 2, 2004 Report Share Posted November 2, 2004 Is it spaced on top or bottom? Stock head or aftermarket head? Quote Link to comment Share on other sites More sharing options...
FIRST BANSHEE Posted November 2, 2004 Report Share Posted November 2, 2004 your pipes could have alot to do with the powerband,you didn't say what you are using. Compression and timing will add some bottom end. Quote Link to comment Share on other sites More sharing options...
theredscout Posted November 2, 2004 Author Report Share Posted November 2, 2004 I am currenlty running the following mods on this machine. 5mm Stroker Twister Crank Taper Bored Stock Carbs Toomey T-5's Cool Head with 19cc domes K&N Clamp-Ons advanced timing stock gearing Quote Link to comment Share on other sites More sharing options...
sredish Posted November 2, 2004 Report Share Posted November 2, 2004 Have you contacted the builder to discuss with them?? Quote Link to comment Share on other sites More sharing options...
roosthrower Posted November 2, 2004 Report Share Posted November 2, 2004 5mm stroker? I didn't know a 5mm stroker for a banshee existed. Are you sure your crank isn't just a long rod? Quote Link to comment Share on other sites More sharing options...
Meat_Head Posted November 3, 2004 Report Share Posted November 3, 2004 http://www.twistercrankshaft.com/cranks.htm they will build it to whatever stroke you want. Running a stroker crank doesnt automatically mean you are gonna have great bottom end power, even a 10mm engine can be weak down low. Quote Link to comment Share on other sites More sharing options...
FIRST BANSHEE Posted November 3, 2004 Report Share Posted November 3, 2004 I am currenlty running the following mods on this machine. 5mm Stroker Twister Crank Taper Bored Stock Carbs Toomey T-5's Cool Head with 19cc domes K&N Clamp-Ons advanced timing stock gearing with your mods you should have a decent lowend, double check your timing make sure you didn't retard the timing that would take any from the lowend.I'd also call the builder and make sure he didn't give you a drag port. Quote Link to comment Share on other sites More sharing options...
hamuel Posted November 3, 2004 Report Share Posted November 3, 2004 is it one of the cool billet cranks??? Quote Link to comment Share on other sites More sharing options...
