Shee angainst yfz 450
Mxzdan
Hey I couple of day's ago i race a yfz 450 that had a gytr pipe and jet kit. I race him with my 2001 banshee that only as some airbox modification he beat me on take of and just after a couple of sec I was behing him butt could not pass him the dirt road was not long enough.
Ah im mad i lost again that 450
should i sell that banshee
Or what should i put to be able to beat that atv
I have dominateur tire
I what to beat him
And by the way is there any good canadien web site for those parts
Well, if it was a close race now, and your bike is stock, try this. Get yourself a good set of pipes. I like the FMF Fattys myself, but I have heard others who have had good results with Toomys or CPIs. Basicly, any aftermarket pipe will kill the stock pipes, but some aftermarkets work better than others. Make sure you rejet the carbs once the pipes are replaces, otherwise the bike will be lean and burn up. Once you have the pipes, you can advance the timing. There are several ways to advance the timing. The cheapest way is to remove the stator, and use a dremel to elongate the holes on the mounting plate the stator sits on, so that you can advance it 3 to 4 degrees. You can also change the timeing with a degree key ($25) or with an aftermarket timing plate ($100), any way you do it is fine, so long as you only advance it by 3-4 degrees. Next, increase compression. This can be done with any of the aftermarket heads ($250-400), or by having the stock head shaved by a machine shop($30-45). By increasing compression, you will gain power, but if you increase compression too much, you will have to run race fuel. Stock compression is only about 110 psi, and you can run 150 psi safely on premium pump fuel. I actually run 160 psi on pump fuel without a problem, but I have had others say that this is on the edge.
By now, you should have what you need to beat this yfz 450. If not, then the nex step would be to take the top end off and have the jugs ported by a reputable shop. You can realy gain alot of power by having it properly ported. While you have it apart for a port job, this would be a good time to have it bored to the next piston size and replace the pistons with a fresh set of wiseco pistons.
Now you should be able to smoke him so long as you know how to hold on.
