01bansheefox Posted October 21, 2004 Report Share Posted October 21, 2004 Was looking at a banshee but it has alot of rust, not sure if its just surface rust or what but its fairly cheap, should I bother or not? It is going to be a project shee if that matters so I am tearing it down if I buy it. Quote Link to comment Share on other sites More sharing options...
brock_fuzzy_69 Posted October 22, 2004 Report Share Posted October 22, 2004 if its jsut light surface rust it will be just fine for light surface rust on my car i used cans of a rust removal type stuff cant think of the name of it any automotive paint store prob has it tho maybe i will be nice and look at the can later on to give you a name for it basically you scuff up the surface rust and remove what you can then this stuff is sprayed on over the rust pitting that is still there it turns a dark purple color and then you can sand it off a little bit and spray some primer over it it neutralises the rust and seals it so it wont continue and this way you get the fun of strippin her down and painting it whatever color you want it to be Quote Link to comment Share on other sites More sharing options...
01bansheefox Posted October 22, 2004 Author Report Share Posted October 22, 2004 Soo more than likely a banshee should just have surface rust? Its a 2002 so its not like it has been sitting outside for 20 years. Quote Link to comment Share on other sites More sharing options...
KGL Posted October 22, 2004 Report Share Posted October 22, 2004 02 shouldnt be a rust bucket yet?... check for other abuse. If all seems well , go for it . Sandblast the frame =good as new. Quote Link to comment Share on other sites More sharing options...
