just rebuildt her and now she starts hard
i just rebuilt my brothers shee, all stock except for a k&n, bored .60over, she holds about 110 on each side now on a cold engine. The thing is, it starts really hard, about 20 kicks, even had to pop it once. It is almost broken in, so it hasnt really been riden yet. But i was wondering if running it richer would cause it to start harder. Mixing 24:1 for the break in and the main jet might be 1 to high, will this cause hard starting?
Thanks
Justin
If it pops..it's not getting enough fuel. change the jetting. Also check your spark. When I rebuilt my machine the first time, it had the same issues. one of my jets was clogged and it was too lean. When I last rebuilt my shee....she started on the first kick..no bullshitting. Of course I had done a complete rebuild frame and all. replaced the entire electrical system. Tired of the intermitten sparks, days of no starts and just plain tempramenatal status. Now she'll start on the first kick almost every time and if by the third kick..usualy I forgot to put the key in and then it'll start right up. Your overlooking somthing simple. don't be lazy..tear it apart and look for something wrong..then fix it. Don't know how many times I would be kicking myself in the ass at the track because I overlooked somthing simple.
it has a somewhat newer coil, but i will go back and check some stuff out, I know that the carbs are all good, took them all apart while the cylinders were gone and cleaned them out realyy good, it dont bog or nothing, just really hard to start, once it is warm it usually statrs first kick, but its a bitch to start when cold
You're running 24:1... that makes the fuel mixture lean on fuel. Starting has to do with the pilot circuit. You're not going to kick it hard enough to make the fuel pull across that main jet. I've seen a pilot that had some link clogging it make it run bad. Make sure you have the choke tube between the carbs!! and the slides are in correct... cut away to the back. The cut away being on the bottom of the slide. Those are a few things people forget when putting them back together.
chocke tube it there, slides are in there too, so what you are saying that the gas and oil is too thick to get through the jets? I dont know if i completly understood you. Should i just live with the hard starting till the tank is gone, then start running 32:1 or 40:1? Or should I go up on the mains
He's not saying the gas is to thick, he stated the more oil you use the less gas ther is, making your fuel/oil ratio lean on the fuel side banghead
If you cleaned your carbs, make sure you didn't reverse the float bowls. The bowl on the left carb should have a gold ring on the front of it. It has something to do with the choke, so if they get switched, your bike will start hard cold, but start easy once it is warm.
Exactly... it was just a comment. Maybe you are to lean on the choke circuit will that much oil. Mine is usually hard to start after a rebuild but only the first time. After that it's usually fine. Your compression will go up after the rings seat also.
