toolman Posted October 13, 2004 Report Share Posted October 13, 2004 Clymers states .0024-0026 this seems to tight i have talked to some shops they say they bore to .005 clearance Mine measures.006 larger on both cylinders than the pistons i had 120psi on both cylinder when i took it apart. I measured the bore with a bore gage the piston with mic What about ring end gap is .012 - .018 ok. per cylmers Just so you know i took it apart for a trans problem. thanks Quote Link to comment Share on other sites More sharing options...
SDD Posted October 13, 2004 Report Share Posted October 13, 2004 It depends on how good of a machinist bored/honed your cylinder and how easy you are on breaking in your motor. I have .003 clearance on my cylinders but I take my time warming my bike up before each ride. Quote Link to comment Share on other sites More sharing options...
PassionRE Posted October 13, 2004 Report Share Posted October 13, 2004 Dont bore to .005! On forged pistons and stock porting bore to a final spec of .003". If your engine is ported for substantial RPM increases take it to .0035"...Jim Quote Link to comment Share on other sites More sharing options...
