Timing
I searched the forum but didn't find the answer I was looking for. I just installed a 200 watt stator with timing plate. Other than FMF fatties, jets and a uni filter, my bike is stock. Someone here recommended running the timing at +4 on a bike that had a trinity carb and some other work. Is this also a good setting for a fairly stock bike?
Why only stop at +4 deg? I was informed by a couple of builders that the stock ignition pulls timing out of the ignition on the top end anyway? Thus, if jetting is monitored (which it should be anyway) more advance will only help the bottom end.
My timing is set at +6 right now, my next trip to the dunes I'm going to set it a +10 and see how it does.
Sweet. Thanks guys. I set it at +4. Going to Glamis this weekend so i'll try it out. I am also looking at cool heads. I see that you guys recommend NOSS heads. Any recommendation on dome size? And will I need to change the timing again? :shrugani:
The timing can stay and Dave at Noss will let you know what he thinks as far as dome size depending on what fuel you want to run, elevation, timing, porting, etc...
  • 2 weeks later...
any thing smaller than 21cc domes and you will have to run race gas due to detonation. how exactly do you advance the timing any way. can it be done with out buying a new plate and which way do you move it?
Edited by fast500#12
You have to machine your stock stator plate. and you rotate counterclockwise
I belive is 4.5mm for 4degree's when I measure my ricky stator plate.
