bansheeman454 Posted October 10, 2004 Report Share Posted October 10, 2004 Is there anyeasy way i can make my shee's thumb throttle not be so hard to push its like harder than any quad ive ever had so does anyone know a way to do that>? Quote Link to comment Share on other sites More sharing options...
limitied03 Posted October 11, 2004 Report Share Posted October 11, 2004 (edited) ive come to expect that from mine and alls i can say is either go to a 2 into 1 carb setup or get a stronger thumb.... Edited October 11, 2004 by limitied03 Quote Link to comment Share on other sites More sharing options...
98bonerSTOCKshee Posted October 11, 2004 Report Share Posted October 11, 2004 Is there anyeasy way i can make my shee's thumb throttle not be so hard to push its like harder than any quad ive ever had so does anyone know a way to do that>? when was the last time you lubed the cable? I always find that when it get stiff it's time for new cables. How old are your cables? Quote Link to comment Share on other sites More sharing options...
racer Posted October 11, 2004 Report Share Posted October 11, 2004 a new cable is a cheap and easy way to make your cables a little easier to pull. while you are into this matter think about doin the clutch cable also. it made a world of difference in my lever effort. Quote Link to comment Share on other sites More sharing options...
fixitrod Posted October 11, 2004 Report Share Posted October 11, 2004 You can also cut some of the coils out of the slider springs in the carbs. I've cut up to 6 in aftermarket carbs and never had a problem. Replacing the cable or lubing them with a cable lube system is a must. The cable may seem fine with no resistance on it if you pull it off to check it but it's a different story when you put the resitance of the carb springs or cluctch on there. If you've ridden other banshees that seem like they don't pull as hard, most likely it's your cable. Quote Link to comment Share on other sites More sharing options...
