kotin6 Posted October 8, 2004 Report Share Posted October 8, 2004 My banshee has started to blow oil from where my SST's meet up to the motor. It has not affected the power or anything and the oil has not gotten lower. It is however dirtying up all my bling and pissing me off. Anyone know why this is happening or how to stop it? Quote Link to comment Share on other sites More sharing options...
banshee76179 Posted October 8, 2004 Report Share Posted October 8, 2004 (edited) Sounds like ur rings r shot..../or rubber seal in ur pipes Edited October 8, 2004 by banshee76179 Quote Link to comment Share on other sites More sharing options...
banshdog Posted October 8, 2004 Report Share Posted October 8, 2004 This is something that never happened before? just now starting? have you recently removed the pipes or done any modifications? Quote Link to comment Share on other sites More sharing options...
kotin6 Posted October 8, 2004 Author Report Share Posted October 8, 2004 started after I changed my pipes from stock to the SST Quote Link to comment Share on other sites More sharing options...
banshdog Posted October 8, 2004 Report Share Posted October 8, 2004 (edited) Mine did that when i put on my pro circuits. for 2 reasons: 1. the stock holes on the exhaust mounts did not line up well. i drilled new holes where the pipes fit against the motor the best. 2. when i got my pipes i did not get any gaskets with them. so oil in the exhaust was spitting through even the tiniest gap. with the top end gasket kit i just put on, i got two gaskets for the exhaust. these should tighten up the gaps alot better. so......did you use gaskets when putting on the new pipes? i was told that RTV works just as well, if not better. try that maybe. Edited October 8, 2004 by banshdog Quote Link to comment Share on other sites More sharing options...
hamuel Posted October 9, 2004 Report Share Posted October 9, 2004 sounds like 2 dead o-rings in the pipes Quote Link to comment Share on other sites More sharing options...
kotin6 Posted October 9, 2004 Author Report Share Posted October 9, 2004 That sounds like the problem. I didnt get any gaskets with my pipes and it said everything I needed was included so I didnt think I needed any. How the hell am I suposed to find those in Italy? . I'm sure Ill find some thanks for the info. Quote Link to comment Share on other sites More sharing options...
01bansheeke Posted October 9, 2004 Report Share Posted October 9, 2004 o-rings in the pipes. cheap fix. Same thing happened to me. Quote Link to comment Share on other sites More sharing options...
kotin6 Posted October 10, 2004 Author Report Share Posted October 10, 2004 where can I get some? Quote Link to comment Share on other sites More sharing options...
J.J. Posted October 10, 2004 Report Share Posted October 10, 2004 My banshee has started to blow oil from where my SST's meet up to the motor. It has not affected the power or anything and the oil has not gotten lower. It is however dirtying up all my bling and pissing me off. Anyone know why this is happening or how to stop it? You need to remove the o-rings from the stock exhaust and put them in there. The oil leaking out will have no effect on the oil level in the gearcase. Quote Link to comment Share on other sites More sharing options...
kotin6 Posted October 10, 2004 Author Report Share Posted October 10, 2004 I checked the stocker pipes and couldnt find them. If I do not find them is there a way to get some new ones? Quote Link to comment Share on other sites More sharing options...
frocashmoney24 Posted October 10, 2004 Report Share Posted October 10, 2004 yup, www.rockymountainatv.com you can get a whole new oring and spring kit for the pipes from fmf, should tighen em right up so no more leakin and they send over seas, good luck man Quote Link to comment Share on other sites More sharing options...
Oilsmoke Posted October 10, 2004 Report Share Posted October 10, 2004 Kotin Don't they sell Yamahas in Italy? Go get some new ones from the dealer Quote Link to comment Share on other sites More sharing options...
kotin6 Posted October 11, 2004 Author Report Share Posted October 11, 2004 Yes they sail yamaha here but it is scootors and motorcyclyes. I took my banshee to a dealer one day and he thought it was awsome but had never seen one before. They told me that they couldnt get any parts for them. The only other one I have heard of around here was about 2 hours away at a car show it was a new 2003 nothing special and they wanted like 10000 euro for it($17900) They had a raptor too and they wanted more for it. Evryone that sees me riding wants to talk to me about it, even after I kill them on their scooter. If they can get to the red light befor it turns green afterwards then they all ways try to talk to me and ask how much to buy it. I will deffinetly sell it before I leave here. Quote Link to comment Share on other sites More sharing options...
J.J. Posted October 11, 2004 Report Share Posted October 11, 2004 I checked the stocker pipes and couldnt find them. If I do not find them is there a way to get some new ones? If you didn't remove them from the stockers then they should still be stuck in the groove on the inside of the pipe, I can't imagine that they would have fallen out when you removed the pipes, mine were pretty well stuck in there... Quote Link to comment Share on other sites More sharing options...
